Hey everyone,
Selling my R34 GTT seats at the end of the week once I put my new seats in.
The drivers side has a split in the stitching but I will have that repaired and they will be super cleaned so you won't have to worry about sitting in someones stank.
As far as I know 3 out of 4 holes will line up with most nissans and one has the be cut and extended I think.
Looking for $150.
Hey all, have some S1 R33 GTS-T bits for sale;
The car had 120xxx Km on it before it was written off by the previous owner, so most parts are in good condition.
-4x stock alloy wheels in 5x114.3 16" spec - $150 (Great if you need to pass defect / for rego. They have a few marks/scratches on them & you will need new tyres)
-Steering rack in good nic - $150
-S1 Steering wheel - a few minor scratches, but complete - $40
-Radiator Coolant Overflow tank VGC - $30
-Brake Fluid reservoir Good condition - $50
-RHS tail light complete (dark green) - includes harness $50
-Standard front swaybar $50
-Std Engine mounts (complete) for rb25det VGC $80
-Left & Right doors (glass for LHS included) - RHS has minor ding but suitable for re-skin. $120 for both (includes handles etc) or $80ea
-Auto Tailshaft $50
Parts are in Bungendore, but I work in the City (Constitution Ave) so can deliver.
All of these prices are ONO - make an offer if you want any of it.
Text me on 0431206336, or PM me if you're interested (no calls please).
If not sold by end of November, I'll be chucking it up on ebay
Cheers,
Matt
I have FOR SALE a Brand New Roof SpoiIer for an R32. I did the the dumbass and bought one of these in the faint hope it would suit my needs but alas no. post-78856-0-41739200-1350373036_thumb.jpg post-78856-0-51282400-1350373059_thumb.jpg Cost me approx $130 posted off Ebay. Will sell for $100. Me loss / you won. Description straight off the Ebay listing, complete with spelling mistakes :
  • This listing is for 1 Piece of roof spoiler as tittle listed
  • Top quality fiber glass
  • White gel-coated finishing
  • Recommand primed before paint
  • Fit Nissan Skyline R32 GTR GTST
  • Easy to install
PM or post here...
Edited by Not a Pulsar
Recaro SR3's with Recaro rails to suit R34 GTT - $800
Rails do not fit R32's :( as recently found out
Apparently the 34 GTT is the only one with a different floor pan.
Woah! Awesome price including rails. Someone with a GTT should get these.
My red SR3's were 900 without rails.
A few things up for sale
- Apexi SAFC (Black) - $250 used
- Greddy Profec B Spec 2 boost controller- $300 used
- GCG GT30 0.82 rear housing (internal wastegate) - $400-$450 NEW
- wastegate actuator 12PSI w/bracket - $100 NEW
- 5 bolt dump pipe - mild steel - $150 NEW
- Oil cooler/relocator kit (fits RB) - $180 used
- R32 GTR wing - Dark metallic blue - $150 used
- Kinugawa TO4E oil drain - $50 NEW
- HKS SSQV (comes with circlip/2bolt mount to fit RB25DET standad BOV position $100 used
- Stock RB25DET ECU - $120 used
- Stock RB25DET Air Flow Meter - $120 used
- 2x Federal 595SS 245/45ZR18 (lots of tread) - $100 used
- Tein HA Coilovers to suit R32 GTST front pair (felt fine when in car 2 years ago) - $200
- Trust Airinx air filter - $100
All prices negotiable. give me an offer.
PM or text 0431900505
will post pics eventually, can send pics if requested
Would prefer local sale
located in Woden, ACT
Cheers
Simon
Locals
I have for sale;
6x siemens deka 610cc high impedance injectors 14mm (just been flow tested excellent cond) $250
Also if interested an UNUSED Aromotive alloy fuel rail black and a bunch of black -6AN fittings and hose $300 (if no takers i'll return it for more than $300 that i paid.)
Will do package price if someone wants the lot.
Reason for selling they dont fit RB20 as i was lead to belive. :angry:
PM for pics of info.
Edited by FJ1600
need to buy an r31 manual wagon if it even exists or any r31 manual if possible i know im pushing shit up hill but hey
also the stagea is forsales for only 8k
All supporting modes have been done 100,000k service done 19" rims did touch screen gtr buckets big break upgrade and plenty more
It's a great car that snaps necks and quick in a straight line and worries wrx and evo's through roundabouts for its size there is no comparison price is flexible
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
