APEXI SAFC 2 and Metal AirBox (ARC Style) For Sale ----->> http://www.skylinesaustralia.com/forums/topic/430136-apexi-safc-2-and-metal-airbox-arc-style/
Accidentally won more than 1 SAFC 2 on Ebay.
Non ARC Box is Not a Drop in fit in a 33 GTS-t.
  • Like 1
S2 R33 parts interior and exterior.
Parts from $20-$150 more that's bought the more I knock off the price.
Bren, managed to kill my hazards button over the weekend. Any chance you have one?
Yo bren I can see that intercooler pipe sitting on the top.
Wouldn't mind checking if it fits.
How much?
$30 if it fits came off the bro in laws r33 it shortens the track going into the throttle body from the normal ones
Got sent the wrong locknuts for my volks..... jerks.
these are standard style nuts, 60 deg 12x1.25.
So who wants to buy a set of 20 locknuts?
How much you chasing?
Are all of the 20 nuts "lock nuts" or is it 4 lock nuts (1 for each wheel) and 16 normal nuts?
Try OTR in Melbourne
Got great ones for my LMGT4's at an awesome price.
Like you said Mik you can get best quality ones from the Manufacturer who supplies the big wheel branded shops.
Seemed to me OTR had an in somewhere :)
I have a triple gauge din panel, free to anyone who thinks they could use it. It's the one of JustJap. Holds three 52mm gauges though it's designed not to sit flush with the dash.
I ended up making my own so this is unopened in original packaging. Willing to deliver aswell :)
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
