APEXI SAFC 2 and Metal AirBox (ARC Style) For Sale ----->> http://www.skylinesaustralia.com/forums/topic/430136-apexi-safc-2-and-metal-airbox-arc-style/
Accidentally won more than 1 SAFC 2 on Ebay.
Non ARC Box is Not a Drop in fit in a 33 GTS-t.
  • Like 1
S2 R33 parts interior and exterior.
Parts from $20-$150 more that's bought the more I knock off the price.
Bren, managed to kill my hazards button over the weekend. Any chance you have one?
Yo bren I can see that intercooler pipe sitting on the top.
Wouldn't mind checking if it fits.
How much?
$30 if it fits came off the bro in laws r33 it shortens the track going into the throttle body from the normal ones
Got sent the wrong locknuts for my volks..... jerks.
these are standard style nuts, 60 deg 12x1.25.
So who wants to buy a set of 20 locknuts?
How much you chasing?
Are all of the 20 nuts "lock nuts" or is it 4 lock nuts (1 for each wheel) and 16 normal nuts?
Try OTR in Melbourne
Got great ones for my LMGT4's at an awesome price.
Like you said Mik you can get best quality ones from the Manufacturer who supplies the big wheel branded shops.
Seemed to me OTR had an in somewhere :)
I have a triple gauge din panel, free to anyone who thinks they could use it. It's the one of JustJap. Holds three 52mm gauges though it's designed not to sit flush with the dash.
I ended up making my own so this is unopened in original packaging. Willing to deliver aswell :)
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
