Hey guys, just posting this here for a friend. Some of you may have met Dave and seen this car before. (copied straight from fb)
the good:
b18c2 in good health over 190psi compression
clear headlights and amber corners
enkei rpf1 15x7 +33 in perfect condition wraped in hankook k110 90% tread
ASR subframe brace
Whiteline 22mm adjustable sway bar
buddyclub n+ coilovers (no leaks)
SR1 Recaro
DC2 front strut bar
Injen CAI
X force exhaust manifold
custom 2.5" exhaust with high flow cat
timing belt and tensioner replaced under 1 year ago
endyn style crank case breather/catch can
3 months ACT rego
The bad;
paint on the roof is faded
some small shopping car dents (i have a spare set of doors)
will go 5.5k with out the enkei or 6.5 with
post-85537-0-00590800-1389160263_thumb.jpgpost-85537-0-62964000-1389160269_thumb.jpgpost-85537-0-70047700-1389160277_thumb.jpg
PM any interest my way.
Buy my Stuff and Things!
R33 S1 Turbo, Minimal shaft play but condition unknown as unused by me. $150. SOLD.
R33 S2 Turbo, Minimal shaft play but condition unknown as unused by me. $180.
R33 side indicators. $15 / pair... (more than 1 pair available)
Stock Rubber intake Pipe for GTS-t $15 (more than 1 available)
R33 Coupe Rear Garnish (Clear) $50.00
Various NISSAN Relays $10 each.
GTR BOV $80 (More than 1 Available) 1 SOLD Pending Payment/Pickup.
Some piping for GTR Bov also.
GTS-t Bov $40
R33 Crossover J pipe $20 (more than 1 available)
Stock R33 GTS-t Dump $20
New Never Used Stainless Split Dump Pipe $80
Stock R33 GTS-t Frontpipe and Gutted Cat $20 SOLD.
3" GTS-t Frontpipe larger section welded in the middle. Ugly but Effective. $40 SOLD.
Stock Series 2 R33 Coilpacks $80 / set of 6 (more than 1 set available)
Stock R33 Side Mount Cooler $50.
R33 4door Tail lights and Garnish - Both Series 1 and Series 2.
R33 Coupe Series 2 Wing (White) $100
R33 4door Wing (Silver) $100
R33 GTS-t Airbox and Snorkle $100
**More will be added in time...
**R33 GTS-t RB25DET Rocker Covers $100 pair, I might even clean them for you.
**R33 GTS-t Stock ECU Series 2... $100
Series 1 ECU SOLD.
If it's Not Listed, I may have one... Just ask.
PM is best. Pics can be provided.
Putting this backup for sale again, found another car that requires my ownership and I need to free up some space for it.
1993 Skyline Gtst R32
183xxx kms
Manual
New HD Clutch, less than 1000kms, rear main seal done at same time
New radiator
Bilstein shocks
Lowered springs, unsure of brand
34 GT wheels w/ Federal 595RS-R tyres 99% thread, less than a month old
Turbo timer and aftermarket boost gauge
All fluids (gearbox, diff, brake, clutch) were changed when I got the car, around 4k kms ago
Front mount intercooler
Exhaust
Overall a pretty tidy car. There is a few scratches around the body, has the factory M spec body kit. The side indicators, next to the headlights, will need to be replaced. They are currently held in with zipties, as the little brackets have broken. All mechanical is great, drives smooth and no leaks. The few issues are with the body.
Looking for $7,500. It has rego until Feb 2014, I think will have to double check. I'm happy to put more rego on if the price is right. Not interested in swaps, looking for a straight cash buy as I have another car lined up to buy.
For anything else, feel free to send a PM. Can also PM pics if interested.
More details of the Hyosung i've got:
It has done just under 50,000km
Has newish brakes and brand new front tyre.
Runs perfectly used it daily until i did my back. Was told i can't ride this style of bike anymore.
Will need new rear tyre to pass RWC. Otherwise it will pass.
Will also need a new seat at some point. They are $100 from hyosung spares.
Looking for $1000 from SAU people. If not ill throw it up on facebook for like $1500.
1992 Suzuki Swift GA (Red) up for sale if your interested. 5spd manual.
220,000kms with 3months Rego and current RWC. Very tidy unit.
Has just had the exhaust fixed, windscreen replaced, will do the Oil, Filters, Plugs and a detail this weekend.
I will be looking for around what it's cost me to date in total and a few bucks for my effort. So under $1500
Pics up after this weekend. But for now this is how I picked her up last week.
cleaning up a little and found some thing.
free to the first person that picks them up or they go in the trash.
- R33 replacement leather handbrake boot
- old school hks turbo timer (plugs into the factory plugs under the dash for a 33)
- 2 gaskets ( one cam cover and the other for between the two halves of the stock r33 Rb25 intake manifold)
Still got the following:
Rb26Dett Standard Injectors - $200. Work perfectly.
RB26Dett HKS Atmospheric BOV - $100 comes with pipe.
R32 GTR standard Airbox with near new Filter - $200
R32 GTR standard Cams - $200
Will sell the lot for $600
R33 gtst gearbox sale
Hi guys I have a r33 gtst gearbox for sale has had an overhaul done over a yr ago from award diff and gears. Always used redline oils and always serviced. Reason for sale recently purchased a dog box. Asking 1600 neg
Edited by sime1
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
