R32 Nissan Skyline GTR 1989 imported by me in 2004. $13,500 or reasonable offer.
Complied in the ACT.
I dont get the time to drive it, would like to see it go to a good home.
Located in Canberra but will trailer deliver to you for cost of fuel + hire.
Last rego inspection:
- Back left handbrake was not applying full force.
- One of the engine mounts is split, don't know how long it was like it, never had an issue before, I bought a spare, haven't fitted it.
- Clear is coming off.
Needs a tune, throttle bodies need balancing. I cant afford to get it done.
Steel wheel ball bearing turbos built by Croydon Motorsport, all the under plenum pipes were checked and replaced because the last mechanic overtightened the water bleed screw and it sheared, so when I changed the water pump I couldn't bleed it, had to dismantle the entire inlet side to fix it. Found the paper gaskets blown in two places so put in HKS metal gaskets.
Had the injectors serviced, removed the fuel tank and cleaned the lines out, new fuel lines as well. new timing belt went in a while ago.
Cat back exhaust, HKS Pods, everything else is stock.
My Gloss black GTR Bonnet
Condition is immaculate
has the heat/sound deadener and squirters
$600 (or $700 if you wish to barter)
most have seen it on my GTR or in my mancave
however if you want to drop by or need pics
Just ask
Cheers
Richard
Will also be selling off both sets of my Rays Volk GTC's soon
Gold set to suit GTS-t's (Face 2)
18 x 9 +29 ®
18 x 8 +29 (F)
4 x Federals RSR's on rims Good tread road legal
Minor rash will be fixed first
Sit hella flush on my 34 GTT
$2400
Diamond Black to suit GTR's
18 x 9.5 +15
2 x Bridgestone Potenza's RE050's (road legal tread)
Minor rash is being fixed now
Also sit flush with guards
$2400
Both sets come with Rays Nuts
- Volk CF centre caps
- Socket/s
Payment plans on Rims available if your not so flush with cashish
Interested in those Dimond Black GTCs
Hi All,
I have the following stuff to sell all pickup in Canberra / QBN.
Price is make are offer on here or via PM... My R33 is sold so no longer needed, this stuff will either be ebayed or thrown out
Stock Airbox with high performance filter... good condition
http://imgbox.com/sf**kqx1
Reverse switch (that controls the reverse lights) Brand new genuine nissan.
http://imgbox.com/xqypXZoU
Plastic Box for POD
http://imgbox.com/oFvc0G3k
Clutch and Fan. Clutch is stuffed!!
http://imgbox.com/THybj6ju
RB25det Head... great condition
http://imgbox.com/sKfHLg24
http://imgbox.com/0YnUVuNc
R33 s2 stock exhaust... all the way from dump pipe to back.. good condition
http://imgbox.com/l0c2GHWp
R33 S1 ABS pump... OK condition should work fine though never tested (i had a s2)
http://imgbox.com/eAV1Owii
R33 Stock wheels
http://imgbox.com/vM0IGwzw
http://imgbox.com/WbVGV2uA
R33 Emergency tyre
http://imgbox.com/bmxZHrPT
Hi All,
Plastic Box for POD
R33 Stock wheels
R33 Emergency tyre
And this should be an rb25det block for sale above not head!!
DOWN TO $12,000 - must go.
Also has Greddy Oil Filter relocation Kit.
Just flushed radiator, fitted new battery (SuperCharge batteries are crap), just flushed and put in fresh fuel.
Pretty sure I have fixed the handbrake issue.
Needs a tune. I cant afford to get it done.
Cat back exhaust, HKS Pods, everything else is pretty much stock.
No rust.
Edited by xfixiate
1990 R32 GTR RB26DETT - $22,000 ONO - 0422626173
Up for sale is my 1990 Nissan skyline R32 GTR, It is in great condition with 84,000kms and the original japanese service books, it has been used as an occasional weekend car.
Panasport G7 C5C 3 piece wheels with Federal 595 RSR 255/45/17 (1500kms on tyres)
Greddy Type S Coilovers
Cusco rear camber arms
Cusco castor rods
HKS pod filters
Greddy Cam Gears
HKS Power FC with hand controller
New Nissan injector seal kit with new Pintle caps (installed less than 300kms ago)
HKS electronic boost controller
3.5” catback exhaust with 4” oval rear muffler (nice and quiet)
RDA slotted and dimpled rotors with Intima SR brake pads (installed less than 1000kms ago)
Genuine Nissan Tie Rod ends (installed less than 1000kms ago)
Rebuilt Drive shafts with new CV boots (installed less than 1000kms ago)
Steering Rack boots (installed less than 1000kms ago)
Rebuilt Headlight Switch (installed less than 1000kms ago)
Wheel alignment performed by Capital Steering less than 500kms ago
Edited by JimmyS
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
