just shove the biggest muffler or mufflers under it you can, 16-18" x 11-12" x 6-8" on the back with your existing middle muffler, if its not quiet enough make the middle muffler bigger, hotdogs don't do much in the way of noise reduction and your 5" rear muffler isn't what I would call a big muffler.
my 3" exhaust was legal (90db as tested by the rta and my engineer) and my 3.5" exhaust is just the same or quieter. the loudest thing when you put your foot down is the pod filter/Turbo.
Exactly.
My 3.5" on my GTS-R is 91-92dB @ 5100rpm, so it's just over legal - but close enough for it's size and the added RPM of a 26.
Has two custom made mufflers, big as possible - job done.
  • Replies 46
To get rid of drone you would be best off tuning a Helmholtz chamber to cancel the unwanted exhaust frequency. Larger muffles will make the whole frequency range quieter but the chamber would target the frequency you want cancelled.
The maths behind reflective sound cancelling is quite complex so its best to make an adjustable length setup if you can. I doubt many muffler shops would help you with it though.
With regards to sizing, you would probably gain over 20kw going up to 3.5 inch at the moment, I gained 30kw but deleted the cat also.
My only concern with going a 3.5" exhaust system (cat back) was that it would make it louder. That being said, Im not that concerned with the power level of my car ATM anyway. The car is more traction limited more than anything and is plenty fast for the street.
I was thinking (pending packing/sizing restrictions) chucking the following on to replace the middle resonator:
http://www.magnaflow.com/02product/shopexd.asp?zone=main&id=10009
Then, Ill see how it is after that. For the sake of around $100-150 for it plus installation, Im hoping it will do the job.
Thoughts?
http://www.magnaflow...e=main&id=10009
Thoughts?
you may find you run into space issues trying to fit a 22" long muffler under it, 18" is already taking it close to the axle/diff in mine.
  • 2 years later...
For any of those interested, I took some measurements under my 32 GTST for muffler sizing:
Rear Muffler (largest size possible without interference)
18X12X8
Middle Muffler
16X11X6 (CENTRE-OFFSET)
Keep in mind:
- Depth of each muffler will depend on how much ground clearance you need/want
- Main limitation with the centre muffler size is tailshaft clearance. Running a "centre-offset" muffler appears to allow largest muffler possible without creating an interference.
My AES 3" , 7" diam. rear muffler with a resonator is quiet. I havn't db'd the combo but I expect it to be legal. I did some tests recently and found that the combination of a 3" perforated tube fitted to a 7" diam. housing is about as good as it gets. If the housing is ovalised so the crosssectional area is increased resulting in more packer nothing is achieved in the quietening department. If the length is increased it will become quieter but there is a limit.
"My AES 3" , 7" diam. rear muffler with a resonator is quiet. I havn't db'd the combo but I expect it to be legal. I did some tests recently and found that the combination of a 3" perforated tube fitted to a 7" diam. housing is about as good as it gets. If the housing is ovalised so the crosssectional area is increased resulting in more packer nothing is achieved in the quietening department. If the length is increased it will become quieter but there is a limit."
If it does nothing for noise suppression, then what does increasing the cross-sectional area do?
I might sound sceptical, but I just don't see how having more material to absorb sound will not affect noise suppression...
Edited by R32Abuser
Ok. I have a testing apparatus. I will put a pic on soon. What it comprises of is a large garbage can ( plastic} with a 7" diam muffler inside it surrounded by rockwool. Inside the muffler is a 6" diam speaker. The exit pipe from the muffler also exits the top of the garbage can. I then ( via a cd) excite the speaker with an exhaust noise sample relative to the vehicle the muffler is to be fitted to. The muffler to be tested is connected to the exit pipe coming out of the garbage can. I set my db meter to record the max reading. The reading I got for a 7" diam muffler was the same for a 7" deep but 9" wide ovalised version so it appears that the packer had maxed out initially. Actually I was surprised. They were identical length. I think the same thing will happen for a 3.5" bore muffler at 8" diam.
Looks cool but I wonder how accurate it is, can never beat a proper db test on a car, a speaker just isn't going to create all the same highs and lows that you can't hear with our ears which get absorbed as well.
Edited by Rolls
This technology to test absorbtion , non baffled mufflers , has been around since the 1950's. It speeds up the development process to find the optimum ingredients to suit the application. Obviously there could be a variation in the real world but it is surprisingly accurate. It works for me.
All that happens there (assuming it's straight through) is that the pipe has two gentle bends so it goes between inlet and outlet. It's not like those other mufflers with lots of up and back triple pass bullshit. It's just a convenience thing for fitting it into a given space.
UNLESS you're talking about its muffling qualities...in which case it might be a bit different because one end of the internal pipe is much closer to one side wall than the other. But I wouldn't be worrying about it!
Does it matter if the muffler intake and exit are offset?
I purchased the following from magnaflow before checking about thatMF12589_1000.jpg
I purchased a 16" X 8" X 5" magnaflow item for $200. 3in inlet and outlet and I can guarantee you its a straight through muffler. Pretty much looks like the above ^^^
My reasoning for going this muffler was that it was the largest middle muffler (cross sectional area and length) I could find without going custom. As per my post above, you can fit a slightly bigger item under the car but I was unable to find suitable off the shelf items without going custom. Custom = $$$...
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
