hi friends,
i recently purchased an M35 Stagea complete with service book and logs and owners manual....unfortunately they are no good to me. The car has done 93,000km and i want to work out what i need to do for the 100,000k service. I have scaned the index page, i was hoping someone would be able to tell me which page i should be looking at, and then i can scan that to work out what i need to do and what fluids i should change.
Failing that, if anyone knows what Nissan recommends for the 100,000k service for an M35, let me know. for instance what grade gearbox oil to use and so on.
Thanks, Chris
https://www.sau.com.au/forums/topic/399986-translation-please/
2-3 has the oil types. Here is a translation for the list of contents:
1. Guarantee
Written warranty
2. Maintenance inspection
2-2 Essential maintenance inspections
2-2 Types of maintenance inspections
2-3 Replacement parts. Oils types.
2-4 Maintenance Inspection methodology
3. How to carry out ordinary maintenance inspections
4. How to carry out simple maintenance
5. Service network
Edited by *LOACH*
hi friends,
Thanks, Chris
You would get a better response if you posted in the Stagea section as this has been covered many times.
100k service is a normal major service (no timing belts, VQ's are chain driven).
Transmission oil is Matic J (or compatible) ONLY. DO NOT put Dextron 3/Matic D etc in there as it will very quickly destroy the box.
Matic D is used in the Attessa pump (driver side behind the rear wheel under the car) and power steering.
Easiest thing to do would be to use the Nulon 100% Transmission fluid as it is Matic J and D compatible and is a far superior fluid to both.
  • 5 weeks later...
I understand the Japanese but not really clear on what it is instructing you to do. Something like:
If you want to cancel the switched off screen press the screen quality switch a second time (the screen quality switch will be marked as
画質).
I had a bit more of a think about it and was going to edit the above post but it won't let me so sorry for the double post.
I understand the Japanese but I am not really clear on what it is instructing you to do. It is difficult without having the display to try the buttons. A literal translation would probably be something like this:
If you want to cancel the switched off (or cancel) screen press the screen quality switch a second time (or twice if you haven't already pressed it).
By the way the screen quality switch should be marked as 画質.
1. Guarantee
Written warranty
5. Service network
much appreciated mate....have started the service with genuine coolant and gear oil....all other stuff will be after market. Got the Nulon 100 synthetic ATF for PS and Altessa.....should be completed in couple of weeks as im driving it as im doing it unfortunatly.....Cheers
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
