Hey
Looking @ an ARX
Price seems OK, however I thought Id do some research B4 I commit to anything
The yard seems quite keen to unload it.
http://www.tradingpost.com.au/Automotiv ... 9202054638
If anyone knows of any history of this car Id appreciate the info
Cheers
Posted this elsewhere aswell
https://www.sau.com.au/forums/topic/400073-anyone-know-this-m35-arx/
I think its just a paper filter Duncan, It does have factory cruise though.
Funny having cruise & not audio controls (or both) on the ARX. Does that automatically make it the laser type where you can't set it above ~100km/hr, regularly fail, often disconnect with oncoming vehicles & other quirky features?
Might be right there Scott, it doesnt look quite the right colour for K&N.
Leon - yep, that'd be radar cruise. You can see the radar in the grill - the solid part around the Nissan logo is the give away. It's possible that its been converted to a non-oem cruise but I wouldnt bank on it.
Lol, I can't see squat in the grill - even zoomed in. I'll take your word for it. That grill doesn't look too bad actually, for an OEM one.
mmmmmm.... that takes me back.. looks just like my car when I got it 4 1/2 years ago. (except the cruise control)
The car has the optional safety pack which includes 6 air bags (2 in front, in the sides of fron seat and full side curtain) and rear centre lap sash seat belt.
Looks like a nice example
Thanx for all the posts
If we can unload our current car Ill probably go take it for a drive & see how it goes
Only thing I could see that annoys me is the front seat leather is worn
I know this happens but seems quite bad for a car that has 90K on the clock
The rest of the car seems ablout right for those Kms
Couple of little marks on it, but the cars going to get used for carting kids so not really fussed
Cheers
It probably has 3 times that on the clock. Most do. The odo's get wound back all the time unfortunately.
If you want genuine k's you are best importing it yourself through iron chef.
Lol as I found out doing a language conversion for a certain dealership recently
"yeh we wind them back all the time I actually have someone that comes in and does them for me" lol
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
