Yeh, it could well have been my fault. Kick in the teeth considering how careful I was installing it, I was paranoid about even scratching anything. In any case, I guess it's irrelevant who caused it. It's happened now, better just get on with what I'm gonna do about it. Unfortunately I may be a little bit out of my depth now.
  • Replies 104
Alright guys, I just need to make it clear to anyone who has read/is reading this thread that I can't and don't blame the workshop for what has happened. I was upset yesterday about the situation with my car, and I've run my mouth off a bit in regards to it being their fault. That really wasn't the right thing to do, as this could all have quite easily been my fault, and I accept that and will just get on with fixing it.
Allstar have been nothing but helpful while I've had my car in there, and in fact continue to be helpful despite my comments on here. I guess a little bit of miscommunication between them and me about what exactly happened with the manifold lead to me jumping to conclusions, and voicing those conclusions on here wasn't the right thing to do. I have since spoken to them and they explained exactly what happened and what they did, and it's quite clear now that I am at fault and I apologize to them for what was said.
Edited by Hanaldo
dont you hate it when workshops pull you up on what gets said online in public space in the free world...
I just wish I still had the lower section sitting in my garage that I could send over to you...
The lower manifold isn't an issue anymore, Allstar supplied a new one and replaced it. It's whatever has got or is getting into the motor jamming my valves open that is the problem.
oh, well in that case I wish I had another head to give you...
That one I would appreciate :P
Do they have you at knifepoint, should we send the police ...:P
So how did it break? or are you gunna be all suspenseful again..
I think I've got the knife at my own throat :/ lol. No but seriously. I did jump to conclusions.
Still not clear what caused the manifold to break though, probably incorrect tightening as you said. I fcked up with that bolt at the front by not drilling the hole out, so that has probably twisted the manifold.
Just out of curiosity, how do you tell compression is down on one cylinder under load?
Well it loses compression under full load, it doesn't pick back up straight away when it returns to idle or is switched off, which is when my tuner did the comp test. But after being switched off for awhile, it will get full compression back and is good to go again.
Which cylinder/s
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
