L O L I liked the part about "Honestly you should be happy that they actually have the correct equipment and actually heard the detonation."
and "especially when you have allocated 5 hours for a tune..... and not 2 days"
Who could possibly take 2 days to tune a car? Imagine the bill, hi yes that will be 1600$ please oh and great news it made 6kw more!
Not sure if you're serious or taking the piss but you'd be extremely surprised how many tuners DO NOT use knock detection on their dyno. I know of at least 4 in the greater Brisbane area and not only don't use it, but when challenged about it, simply state how good they are they are able to detect knock without the need for a knock detection device.
I can tell you I was very surprised when I also thought I had a good ear for that sort of thing then someone put a headset on me and proceeded to pull 8 degrees of timing out before I could stop hearing it knock. The car made 10rwkw less after that. The customer didn't blow it up.
  • Replies 77
Posted Images
I always use knock detectors, even if the ecu has it, its hard to hear knock on certain cars over the engine noise and ecu's arnt always accurate, especially vipecs would read huge knock when there was none and read low knock when I could hear it quite clearly. I know a lot don't use them because half the time there to lazy to clip it on the block or there works to cheap to buy one, also yes a lot of cars can take time on the dyno to sort out bugs, but not something as simple as det.
I also know of a big name workshop here in Adelaide that doesn't use knock detection, I won't ever be getting my car tuned there again as when I hooked up some knock ears and reved out 3rd on a warm day it was detonating like crazy.
Really really slack, PM if you want to know who.
UPDATE:
Picking car up tommorow afternoon, if I have time I will post a dyno sheet.
But because I was only sent an 8psi actuator it didnt make a whole lot of power. I'm just glad they fixed the detonation and got it running correctly.
Needs a new rear muffler though, its partially collapsed.
I dunno how these things handle det like that. I freak with the slightest little bit of det and dont push through it.
how accurate is a pwr fc at detecting real knock? or are all computers about the same
I have found they are all different. Some actaully ping at around 35. And some ping after 60.
So without listening and knowing, be carefull
Jez , your knock detection setup is pretty cool and seems to work quite well, not to mention it was probably cheap as. But ill admit at first I had no idea what the hell it was ...
Edited by Mitcho_7
Haha cheers man,iproblem is i spent $900 on the kmon kit and i prefer my new setup as i can hear alot more
Good power but f**k its lean, 12.5:1 =/ no wonder it was pinging lol
I run my own cars at 12.5:1.. never had an issue..... especially as the boost is so low... could go easy 13 depending on engine
I had mine at 12.5:1 pm 19psi dropping to 16 psi making 260kw on a highflowed rb20 turbo on a neo, it also didn't ping which is suprising considering how small the rear housing is.
we detuned to 11.5-12 for safety but you can get away with it if timing is conservative.
What is your new setup?
Its top secret :)
Maybe i should start tuning lean... Seems no body has been melting motors
Its top secret :)
It is a street car, I would be nervous running it above 11.5:1 on the track, though I would be dropping the boost level for safety as well.
What are your thoughts on lean + less timing vs rich + more timing? I've heard the japs don't even use AFR they just use exhaust temp and go rich as hell and smash the timing into the motors.
Is your secret method a garden hose? Ear muffs with a microphone wrapped in a rag? cmon spill.
Wow, ile show you a pic of my SR20's piston when I tuned it to 12.5:1, half the side of the piston melted lol was at 18pound though. I'd never tune above 12:1 now.
Edited by 51NNA
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
