L O L I liked the part about "Honestly you should be happy that they actually have the correct equipment and actually heard the detonation."
and "especially when you have allocated 5 hours for a tune..... and not 2 days"
Who could possibly take 2 days to tune a car? Imagine the bill, hi yes that will be 1600$ please oh and great news it made 6kw more!
Not sure if you're serious or taking the piss but you'd be extremely surprised how many tuners DO NOT use knock detection on their dyno. I know of at least 4 in the greater Brisbane area and not only don't use it, but when challenged about it, simply state how good they are they are able to detect knock without the need for a knock detection device.
I can tell you I was very surprised when I also thought I had a good ear for that sort of thing then someone put a headset on me and proceeded to pull 8 degrees of timing out before I could stop hearing it knock. The car made 10rwkw less after that. The customer didn't blow it up.
  • Replies 77
Posted Images
I always use knock detectors, even if the ecu has it, its hard to hear knock on certain cars over the engine noise and ecu's arnt always accurate, especially vipecs would read huge knock when there was none and read low knock when I could hear it quite clearly. I know a lot don't use them because half the time there to lazy to clip it on the block or there works to cheap to buy one, also yes a lot of cars can take time on the dyno to sort out bugs, but not something as simple as det.
I also know of a big name workshop here in Adelaide that doesn't use knock detection, I won't ever be getting my car tuned there again as when I hooked up some knock ears and reved out 3rd on a warm day it was detonating like crazy.
Really really slack, PM if you want to know who.
UPDATE:
Picking car up tommorow afternoon, if I have time I will post a dyno sheet.
But because I was only sent an 8psi actuator it didnt make a whole lot of power. I'm just glad they fixed the detonation and got it running correctly.
Needs a new rear muffler though, its partially collapsed.
I dunno how these things handle det like that. I freak with the slightest little bit of det and dont push through it.
how accurate is a pwr fc at detecting real knock? or are all computers about the same
I have found they are all different. Some actaully ping at around 35. And some ping after 60.
So without listening and knowing, be carefull
Jez , your knock detection setup is pretty cool and seems to work quite well, not to mention it was probably cheap as. But ill admit at first I had no idea what the hell it was ...
Edited by Mitcho_7
Haha cheers man,iproblem is i spent $900 on the kmon kit and i prefer my new setup as i can hear alot more
Good power but f**k its lean, 12.5:1 =/ no wonder it was pinging lol
I run my own cars at 12.5:1.. never had an issue..... especially as the boost is so low... could go easy 13 depending on engine
I had mine at 12.5:1 pm 19psi dropping to 16 psi making 260kw on a highflowed rb20 turbo on a neo, it also didn't ping which is suprising considering how small the rear housing is.
we detuned to 11.5-12 for safety but you can get away with it if timing is conservative.
What is your new setup?
Its top secret :)
Maybe i should start tuning lean... Seems no body has been melting motors
Its top secret :)
It is a street car, I would be nervous running it above 11.5:1 on the track, though I would be dropping the boost level for safety as well.
What are your thoughts on lean + less timing vs rich + more timing? I've heard the japs don't even use AFR they just use exhaust temp and go rich as hell and smash the timing into the motors.
Is your secret method a garden hose? Ear muffs with a microphone wrapped in a rag? cmon spill.
Wow, ile show you a pic of my SR20's piston when I tuned it to 12.5:1, half the side of the piston melted lol was at 18pound though. I'd never tune above 12:1 now.
Edited by 51NNA
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
