  • 4 weeks later...
Hey guys,
Thought I should drop by and say hi. I have been meaning to for a while but I was waiting for the new ride to be confirmed.
My brother and I have just bought ourselves a DR30 Skyline RSX with the sole intention of racing it and using it as a tool to promote my little online motorsport business AUTOsports Australia.
Some of you might know this car already so if there is anyone that can give us any information on it that would be greatly apppreciated. As we have also never modified one of these any advice woulld be greatly appreciated. We are planning to run the car in Improved Production because we really want to be competitive and keep the car as close the Group A looking as we can! Maybe one day when we have money to blow we'll go and do something crazy in Time Attack with a different car...
On a different note we also have a Prince Skyline GT (my fathers) that is built for group Nb historics. New engine has been a nightmare so hasn't been on track for a number of years but should hopefullly see the track again in 2012.
Back to the DR30. We're going to source S13 uprights and front hubs, plus LCA's so we can run lots of camber and then also run S13 spec coilovers (which I have read about on here) and front brakes although will probably have to get some custom rear brakes done. Any thoughts on this?
ANyway enjoy the pics. Will get more up here soon.
Cheers
Improved Production?
Will CAMS allow S13 front suspension in this class and if they do remember if you have just 1 ROSE JOINT it will send you to sports sedan, no pass go, no collect 200, straight to sports sedan where the big bangers live.
Cheers, D
OH! And if you want to build a motor, I have a bored block, forged pistons, spool rods, reco'ed head, 14mm O'Ring fuel rail, 550cc injectors (new) W series Celica/Supra gearbox with FJ front housing, new clutch, etc etc etc.
Drop me a pm if your interested?
Cheers, D
Why would you have to change to R&P? I know there are some bump steer issues to sort out but with a new tie rod end to suit the S13 upright it will all just bolt in. Or is there something I'm missing here??
dont change to s13!!!!! sorry to be blunt but iv been there and done that and s13 knuckles have bad bumpsteer issuses but worse the "tow in on turns" is wrong it completely ruins the front end geomitry they only way i could see to fix it would be to cut and shut the s13 knuckles (like the drifters do) to match the shape of the dr
its my 2cents only but if you want a dr30 to be a good race car i believe its better to use z31 inserts cutdown mcphersons and weld on strut sleves retaining the cars original geomitry
  • 1 month later...
Running 2 businesses and tried to build a race car is hard.... so I've enlisted the help of a great young bloke at UTS who has started to help me. So the project had been paused while I was working out how to work less at the end of last year, but in the last 2 weeks I've found a complete dry sump setup (off a DR30 so it will bolt in). I have also purchased a Painless Wiring kit - which will be painful, but I can't afford to have it done professionally so this is my next best option. I've also completely stripped the car of all the unnecessary parts (air con, headlight washers etc) and next week we'll be laying out the new wiring.
Before Christmas I also purchased some coilovers, steering wheel, seat, harness, seat mounts as well as a heap of heat shielding stuff (DEI Reflect-a-gold, exhaust wrap etc)
Happy days!
  • 4 months later...
It's been a while since an update... I've been busy re-wriring... The new loom weighs about 1/10th of the old one and I'm using some nice military connectors so that any engine bay wiring can be disconnected at the firewall (whether for an engine change or whatever).
I managed to get the seat mounted really nicely on the factory runners but when I sat in it and my knees were hard up against the smaller than standard steering wheel and my head was almost touching the roof I thought this is not good. So I've got in touch with a young fabricator who is currently fabbing up a custom set-up that will be welded into place through a cut floor. We reckon we should be able to mount the seat at least 100mm lower than it was, which it really needs to be considering the height my head will be with a helmet on and wanting to keep the main hoop of the cage as low as possible.
Thanks to changes to the Improved Production rules I can now run the cage to the strut towers. The bad news is that the dry sump tank which sat behind the strut tower will now be put aside and a Petterson tank added in the boot. I might just modify the existing dry sump tank to become the overflow.
I've also been busy with some carbon sheet and epoxy resin making up dashboard and switch panel bits and pieces... which are now finished and ready to be fitted along with all the switch gear and cutout.
The seat will be mounted next weekend and then after that the cage will start... so much has been waiting on the cage. Can't put the dash in until the cage is in so I can cut it up to fit. Can't flock the dash until the dash is cut. Can't finalise the wiring until the dash is fitted.
It never ends, but we're making progress... slowly.
  • 2 months later...
Finally got the seat mounts done. Been a while coming but can now finally start on the cage as it really determines when the main roll hoop will be.
Also discovered an issue with the rear coilovers. As the coilovers run external canisters and the canisters are in a fixed position relative to the bottom mount, they stick out to where ther wheel should be. Can't even mount up a standard wheel. Not to worry I have spoken to a machinist and we're going to machine another bit out of the bottom mount and rotate the canister about 120 degrees so it faces as far around as possible.
As a side note I will be designing and manufacturing bump steer correction kits for 30 and 31 Skylines who want to run S13 front uprights. So much easier to run S134 stuff than to find DR30 coilovers! Unless you've got the $$ to do custom stuff.
I might mention, being able to cut the floor has meant we can mount the seat about 12cm lower. Using the standard mounts and the seat as low as it could go, my helmet was touching the roof. Now I can just see over the dash. Perfect.
  • 3 weeks later...
And here's the new livery we'll be running. Still a while off yet but the new wheels arrive next week.
Also ran into some issues designing up the new rear brakes, nothing we cant overcome but another set back nonetheless. A little machining here and there and some new caliper mounts and we'll be fine.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
