Im competing in the dutch time attack championchip with my R32 GTR.
Lot to learn for me on this forum as i am the only one compeating
In time attack with an R32 gtr over here.
something about the car,
specs:
Build Rb26 engine,
(87mm) close to 2.7liter
Wossner pocketed forged pistons 8.2-1CR
Wossner forged steel con rods ARP bouten
ACL race serie's bearings
cranckshaft ballanced and polished
1.4mm Tomei MLS kop pakking
1.2mm oil restrictor naar cilinderkop
Tomei competition sump baffle kit
extendid sump 8.5liter
external head oil return
Tomei bronze valve guides
Tomei Valve retainers and folowers
Tomei B type valve springs 10.85mm
Tomei Procam 270graden 10.25mm lift
Haltech 33mhz boost control kit
Haltech platinum Pro ECU
AET T78-33D Single Turbo with trust 48mm external wastegate
Wiffbitz 3.5'' titanium race exhaust
Apexi 145mm super drag intercooler
Injector dynamics 1000cc injectors
Tomei 280 litre per hour in tank lift pump
Paxton aeromotive fuel pump
Sard Fuel Pressure Regulator
HKS Fuel rail, twin fed 11mm
C's quickshift
OS Giken twin plate clutch
Autosaurus 1 piece lightweight propshaft
Alcon Brake system, 370mm front, 350mm Rear
welded shassis+ Full FIA cage
Custom BC racing suspension system (car is sponsored by BC racing).
hope you will like it!
https://www.sau.com.au/forums/topic/400644-pro-import-r32-gtr-time-attack-car/
Yes thats zandvoort haha ;)
your right, its not the most easy car to drive on zandvoort, with the tight turns, hills, and few ''brake killing'' brake points.
normaly im round the 2 minute barier on street tyres (we have to run dot tires in the series).
curently im running Falken RT615 semi's in hard compound, with some softer tyres like R888 ill have to take an
extra 3 seconds, will try that later this year.
first event i'm attending will be superlap battle its 17 of june!
You have to go to assen to, its a nice track for skylines, much faster than zandvoort ;)
Edited by Peter de Beus
Was hoping to do Zandvoort in early August but have some other things coming up which means I can't be os until later that month. Zolder and Spa appear to be a good track for street cars with some grunt. :)
I see the car still has plates. How is Holland for registration of modified cars. The cost to register cars in Belgium is rather scary.
Its quite easy to get plates, they don't look at anything. Most difficult is to keep them, as you cant make more then 98db, but normaly its no problem.
Let me know when you come over!
Spa is the best track there is, together with "the ring" ofcoars!
Hey mate,
What gearbox are you running? Fantastic looking 32!!
Not sure whether you were asking about improving lap times, but if you were :P for quicker lap times IMO ... (all relative to budget obviously)
Your engine looks the happiest bw 5500 to 8000 (I like to
400ps at 4500rpm newer turbos can do this) .... with a t78 there is definately time to be gained coming out of a slow corners 70km/h On the tyres you quoted ... I dare say ur loosing seconds off ur lap times as this will compound into the next turns.
What are ur tire options? The ones u quoted are at least a couple of
Seconds slower per lap compared to a Hankook z221 or yoko ao50
or even bridgestone re11s as these are all in the same class in oz...
Good luck for now !!
:cheers:
Thanks mate,
I know i can get seconds quicker with other tires.
I bought those tires for half the normal price, just to try how they are, i will try the the avon zzr or maby the new federal fz201. Yokohama and other brands are difficult to get, and verry verry expensive. Only yoko's that are available are the ad08, but im not sure how good they are....
I need an extra 10kmph in the slow corners.
It would help me with the slow spooling turbo...
Time to import some track tires! Haha
Will be upgrading the turbo for next season to a holset or gtx series or something like that
Yoko AD08's are one of the best street tyres around if not, the best for basically a street "semi" legal tyre. You would definitely pick up some time using better tyres and more speed in the corners!
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
