Hey guys, I have decided to try and retrim the interior fascia on my SII R33 and also the surround on the driver's side power window.
Anyone done this before?
I was thinking a carbon fibre weave look, done in stick on vinyl.
Or does anyone know where it can be done.
Thanks heaps.
- Mark -
I'm pretty sure The Spoiler Shop do this, as they painted my dash plastics for me (Could of really attempted it myself after looking at the procedure, but wouldnt of got the great results).
I know it costs more then just a strip back + paint, around 300 for all the plastics, but they do a good job.
I also know of some people in the eastern states who got some carbon fibre type of contact and did it themselves but apparently very time consuming! Good luck
redoin the dash and other hard plastic bits is pretty easy the only real problems i had when doin mine was gettin the origional coatin off the its just a matter of platic primer and get a paint guy to mix up a few spraypaks of your color for the best finish spray it with clear afta it took me a weekend to go from s#@$y worn dash to nice silver blue and not to many swear words either
I can do it myself but problem is I don't have a workshop to do it. And doing it in an open space at my place means while paint is drying dust/dirt particles could landed on the surface and spoil the result. I had this done on my speedo surround, because it was a small part, as soon as I spray it I took it inside and cover it with a box. Dash facia is a different story as it's way too large to find a box to fit to cover it. So I'm sticking with black on mine, but silver would be nice.
Seen blue, red, carbon fibre texture (stick-on) but never seen gunmetal. Anyone tried gunmetal before?
The easiest & cheapest solution to the scratched dull grey look , is to scrape off all of the grey paintlike finish & polish the black plastic underneath :D It's a bitch of a job , but looks great in shining gloss black :P
Thanks Bro, that's a top tip ! :(
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
