Hi All,
I was wondering if anyone had some spare dial faces (just the faces, not the actual dials or cluster) from the R32 GT-R and GTS-t that they might want to part with for free or a nominal amount?
Why? Well I want to try and organise some reverse-el dials through speedhut (http://www.speedhut.com/) but I need some dial faces to send them.
So, can anyone help?
Updated: Please see newest post
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/40141-r32-gt-r-and-gts-t-dial-faces/
Bump.
Someone must have a spare set for a good cause?! In case its not obvious, you would get them back too...
LW.
I have all the gauges you want sitting here but there complete and im buggered if i know how to get the faces of without buggering them
When you remove the dials from their housings, are there any screws on the dials for releasing the face?
Hmm.. might try and find some close up shots of the cluster as the maintenance manual doesn't say if you can remove the faces.
If the faces can't be removed, would you still be willing to loan the actual dials?
Thanks,
Lucien.
Here is a guide describing how to get the faces off the Z32 cluster -- I imagine the R32 dials will be very similar:
http://www.uniqueautosports.com/IndiglowGu...uageinstall.htm
LW.
Ok, I have just heard back from SpeedHut. They want a complete cluster, not just dial faces, and they don't return them, so I think that puts an end to legend01's kind offer.
Does anyone have a broken R32 GT-R cluster they would like to sell/donate?
LW.
  • 2 months later...
  • 1 month later...
  • 1 month later...
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
