Hi guys,
I'm a little bit paranoid at the moment.
Here is a background of events:
- I parked my car and locked/armed it etc.
- Eventually I came back to my car and noticed some shady looking guys waiting in their car parked behind mine (parallel parked - but with thier engine still running and headlights on) - they seemed to be giving me the eye. But I didn't really care to take more notice.
- At this point I did not un-lock my car - because I was chatting to my mate and had no intention to leave straight away - we just wanted to chill outside the car.
- About 15~20mins later, I decide to leave (the shady guys still with thier engine running)
- I un-locked/disarmed the car via the remote
- After about 5 seconds the guys just drive quickly away.
I'm "suspecting" they may have have had some sort of scanning device - waiting for me to unlock my car via the remote, to "copy" the signal from the key to car. Which I imagine they could use to potentially steal my car.
- Is it something I should be worried about? or just a big coincidence?
Cheers
Chris Rogers is the SAU guy to PM about this but...
Our next door neighbour went away with friends in a convoy across the outback. At a common public carpark they also like yourself noticed a couple inside their 4WD, but didn't think anything of it. All the couples left their 4WDs for a walk and when they came back, 5 of the 6 Landcruisers were rifled of cash and valuables. Patrols and Pajeros remained untouched.
Is the remote a rolling code type?
If you have a name brand alarm from the past 15 years they have code rolling ( hopping ) and cant be scanned Domt sweat it
Not the same for remote door openers on a house
You would be more likely to be car jacked and your habits watched
And if the alarm keeps going off DO NOT disable the siren or disarm it , thieves set it off over and over till you get sick of it and think you have a problem , then kiss your car goodbye
GPS tracker and not the jaycar spec model is highly recommended , club lock and 3 point alarm min and common sense will stop most crims or joyriders, methheads
Anything the factory / dealer imstalls. Is junk
Amd could be bypassed by a crim
I think it was a coincidence , ( toyota has a weakenss as well but cant disclose what it is in public ) plus never leave anything in a car or truck even in a remote location , trailheads get hit all the f**king time here for dayhikes , the opportunity is too great for thieves to walk away from a car full of gear destine for the pawnshop for drug money , savages you can have anything nice anymore ffs
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
    • Really, low/midrange torque goes really bad?? I want decent acceleration, maybe I use a stock rb25det neo manifold?
