Having a few issues with the the car when on the road in any gear if it hits .5 bar the engine cuts very smooth cut, no struggling no missing just bam that it nothing. untill your fully off the accelerator then it comes back to life, you can have the throttle 3/4 open and will rev to limiter.
history of things i have tried,
removed all turbo side replaced all gaskets lines that looked bad and clamps.
replaced TPS and AFM
removed factory boost solinoid and run manifold pressure to wastgate
removed all cooler piping and replaced some clamps all ok
changed plugs gap .8
running out of ideas?
https://www.sau.com.au/forums/topic/401653-r33-gtst-boost-issues-05-bar-cut/
stock ecu on it, have an apexi boost gauge i have just connected for testing. makes boost ok but at about 6k its creeps up slowly from .45 bar and when it hits the .5 it cuts.
That was my first thoughts it was hitting the boost cut but my understanding thats at 1.2bar?
There is no "boost cut" on Nissan ECUs (alright, on the Neo, which actually has a MAP sensor connected to the ECU, there is a boost cut). But certainly not a boost cut on R33 ECUs.
What you DO have is a load based cut. When the ECU calculates a TP value (based pretty much just on AFM reading) which is too high, you get a cut. This can actually happen at a whole different range of boost levels, depending on how much other modification the car has (exhaust, bigger cooler, etc) and the weather, etc.
What I would suspect is that the boost gauge you are using might not be accurate, and somehow you have more boost than you think you do. Consider this one unlikely. Or you have a big boost leak that you haven't found, leading to high air flow at the correct boost in plenum. Or you have a faulty AFM.
Ok changed a few bits has made it abit better.
Timing was set on 0deg so set cas to 15deg.
Factory boost gauge sensor was missing so grabbed one of another wreak out back now factory cluster works only goes halfway up won't go to the 7, which should be correct for 7psi.
Have connected factory boost solinoid.
Seems to get to 6500rpm now then cut.
Can't be afm as I have changed that.
But have noticed there is a beep from the ecu when it hits the cut?
limiter is at 7200
And I know the factory gauge 7 on it is about 14psi that what I said it only goes to half which would mean its running 7pis = .5 bar or there abouts.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
