It will definitely fit a PNM35; I made one for Alex's (PN Mad) HKS fed beast in the last run.
The only issue will be delivery cost; I can get a shipping quote, and them we can go from there. Shoot me a PM to remind me, and I'll get back to you later in the week.
Cheers, Dale.
Dale
Sorry mate I wont be going ahead with this now, as I ended up making my own.
Lol! I didn't really do a pink one, yours is glossy, badass black; just like the rest.
Unwrapping it though... :whistling:
Devo. Here I was thinking I'd have a limited edition colour!
Lolz guise; if I'd realised the demand for pansy pink; I'd have doubled the price & brought out a limited edition...
Update; Braces and mounting hardware are bubble wrapped, in cardboard tubes and labelled for shipping.
Tracking documents all filled in to make life easy for the Post Office chicks, and if possible; they will be going to the Post Shop tomorrow, as I think they still do Saturday morning Parcel drop off.
If not; they will be going in early next week. I'll PM individually with a tracking number once they are on their way.
Thanks again for your patience and support with the group buy; won't be long until you're unveiling my shiny my black rod.
Enjoy lads.
Edited by Daleo
Enjoy lads.
time for another kind of bracing...3-point strut bar? :P
I have another part for stiffness! Need to talk to someone who has a M35 Chassis Jig though!!!!
Anyone got one!!! :domokun:
If I cannot find one I'll setup another Group buy.
P.S. This will take away the need for strutt brace......not that we needed a strutt brace anyway with our chassis but is a need!!! :cheers:
Edited by Jetwreck
It definitely makes a difference, so why not!
I am curious though how much of a difference the chassis brace is going to make when I've already got the strut brace.
Considering most of the steering & braking forces are channeled through the compression rod (piano); which is right next to where the brace mounts, its effect is quite pronounced.
Double A arm front ends don't load the strut towers in the same way that Macpherson strut arrangements do. Macpherson struts tend to push the strut towers toward each other as they compress; which effect camber & caster (and therefore contact patch).
Double A arms tend to direct the forces more efficiently upward; rather than inward, and the arms and shocks actually work better; so a strut brace has a lesser effect. Not NO effect, just LESS effect.
When you see how little support our chassis rails have (the crossmember is about a foot further forward); and how much force is directed diagonally back into them, you start to understand why such a simple brace makes such a big difference.
I know it might sound like I'm just pushing my barrow; but it does work, and it works well.
If I was able to fit the bar to your car, and get you to drive a course; then take it off (but not tell you), get you to drive the same course again, you'd know instantly that it was gone.
I have both strut brace and subframe brace. Strut brace did SFA but after taking out the stupid catt mounts (NA models) and fitting the subrame brace, it works wonders. Can not wait for the rear subframe brace
Glad you're happy Matt. ;)
where we up to with the orders for these things, i forgot all about it...
Daleo i think you can make me a front brace before my car is put back together, will it be different with a turbo and no dual cats etc ?
Hi Nate, I think I have a spare one; let me check tomorrow and I'll PM.
Should be fine; if you haven't already done the exhaust, you'll be able to work around the brace.
Scotty has a 3.5" system, with a 2" wastegate pipe running through there, with a brace fitted; so you shouldn't have any great issues.
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
