Nm35 Stagea Front Chassis Brace
Daleo
 Share
  • 4 weeks later...
  • 1 month later...
  • 2 months later...
Hey people,
The R33 GTS-T / GTR rear strut brace is a perfect item to fit M35 Stagea front chassis.
Remove the end brackets and throw out.
Remove both centre back nuts and throw out.
The tubes and centre bolt are a tad long so I cut 10mm off one tube section and 10mm off one end of the centre bolt.
775 centre to centre is the magic number.
I used 50mm x 12mm hex bolts to connect to the under carriage. Spares holes illustred by screw driver. No need to unbolt anything :)
You'll need to drill out the holes in the braces to 12mm, existing is 10mm
Done for $50 in 20 mins and strong as buggery.
  • Like 1
Tried fitting it two ways, over and under the brace.
Over is better, sits a bit low under.
Great front end stiffening.
Use a reamer to increase holes from 10mm to 12mm.
Plenty of these braces available all the time :)
I
  • Like 3
 Share
    • Hey all. I'm up to doing my oil and water feed lines. Has anyone done a tutorial on this on a 25det Neo? ( I know i should be asking for a tutorial on how to use the search instead, but I couldn't find anything specific) I'm running a Pulsar 3584 on a 6 boost manifold. I could use some advice on what fittings, sizes and where to run the lines. Thanks for any help.
    • Hi, I have someone interested, if it falls through I'll let you know.  I have a brand new set of fronts that  I sourced from Bilstein UK, now revalved and complete with springs to go with the very lightly used rears, if you are interested in a full set. As Duncan has mentioned this is not my job, I sold my suspension business over 10 years ago, but I am here to help when I have the time.  To give you some idea of my schedule I was at SMSP for the State Championship for 4 days the weekend before last.  Then The Bend for 4 days last week and back at SMSP testing this week, a day visit to One Raceway, then the SMSP Day Night meeting the weekend after.  I was hoping to squeeze in a dyno day with Scott on my R32 this week, but that's not going to happen, that's the second time I have had to postpone. Apologies if my responses are slow.   Cheers Gary
    • Talking about tools, my trombone cleaner arrived, talk about weird speciality tools....
    • Ha ha ha, I read that he had it based on brownie points so knew it wasn't going to be sold   I also am only shit stirring on buying, while they'd all be great cars, I don't need more, I actually sold one a few weeks ago. And immediately bought more tools...
    • I thought you might have asked about the Honda, but as the boy just wrote off his Patrol, and was trying to find a cheap daily to get by with, I decided to give the Honda to him
