hey guys,
so i am very confused at the moment weather to buy an RB25DET series 2 or an RB25DET Neo for my NA r33,
i have been working on my NA for 3 years now and its all set up for a turbo engine (yes i know wasite of money but this was my little project since ive had my P's) and since i am off my P's now, the time has finally come for a new engine!
but i am so confused between the two on which to get as ive had two offers as i can get them both for around the same place basically and both in very good condtion!
my car is a drift set up.
so what do you guys think i should put in my car?
i am also going to work the engine for about 6 months before i put it in.
So hope to hear some ideas as i do not know much about engines at all actually ! haha
just know im not a fan of what the Neo's look like :P
https://www.sau.com.au/forums/topic/401797-rb25det-or-rb25det-neo-in-r33-na/
If you can't get a neo for cheap enough go a S2 33 engine but yeah neo. What kind of work are you going to do to the engine? I wouldn't touch it apart from bolt on, if you read the 25dyno thread it will give you some ideas.
Edited by 51NNA
yeah i can get the neo for basically the same price as the S2 RB, i just dont know much about them at all, i did some research and on them they sound good, but it just confuses me even more as i know nothing about engines! not sure what engine work im going to do, how come only bolt ons?
There's alot of threads around that explain what bolt on's you need, but depending on what fuel (E85 or 98RON) you're running this what what you need for 260-300kws
750-1000cc injectors
GT3076 TD06 25G T67 25G or Hypergears std manifold replacement turbos if you dont want to spend 1900$ on a 6boost with wastegate
Bosch 044 fuel pump or equivalent or bigger
Aftermarket ecu, Autronic, Vipec (is just a link G4 but more expensive) Link G4, Haltec or if you're awesome like me Microtech LT12s yewwww
Forward Facing Plenum, yes no maybe so, mostly for looks under 500hp.
3.5" exhaust
BUT
I'd consider upgrading brakes and a decent set of coilovers frist, unless once again if you're awesome like me have NA brakes :woot:
Edited by 51NNA
neo is hands down a better motor, everything about it is better, plus it is newer, I wouldn't ever consider a 33 one.
Only downside I will have to say for the NEO is parts will cost you more. Many things are specific to the neo motor and therefore harder/more expensive to find but they are a great motor
like what? everything from r33 is bolt on, you can even bolt the entire r33 intake onto a neo motor if you want.
Injectors are the main part that can cost a lot if you don't research. Coilpacks are different but cheap enough anyway (was a pain when people were able to source factory coilpacks for good prices for every but neos).
Actually now that I think of it that is all there is with the motor side. Other pain in the ass stuff is having a pull type clutch and different suspension struts to all other models (GTR do fit but not properly).
NEO motors come std with GTR rods and N1 spec oil pump plus the solid lifters
Someone will correct me if I'm wrong though
they also have a much better flowing head, basically the same as rb26 head just with shim over bucket instead of shim under bucket which can cause issues if they spit one out, pretty unlucky for that to happen though.
Mine made an extra 20kw when going from an r33 motor to neo, 230 - 250kw with the same turbo.
go neo if you can, the neos extra 20kw comes from the turbo, 33 and neo de's are rated at same kw
the rods are stronger but the pistons are pretty equal which is what people usually break first?
solid lifters are awesome but with most of us making max power by 7k you shouldn't be revving past the hydraulic limit anyway
with both engines in good condition should produce a very similar result with same setup
Edited by WMDC35
I meant I made 20kw extra due to the better flowing head in the neo, my turbo was right on the limit and out of flow but by removing a restriction in the head (33 to neo) I was able to make more power, if you aren't flow maxing your turbo it won't make much difference htough.
Pistons usually break due to detonation, if you have a det free tune they will handle 400rwkw.
Correct me if I'm wrong but I believe 184 kw vs ~ 206 .
I can't remember what Neos get injector wise but replacing wouldn't be harder than real sidefeed alternatives . I'd like to think ID1000s would drop in but not sure there .
A .
They are pretty much a drop-in item, just need to rewire the standard connectors with the ones that come with the ID's.
This is definetly true. Still worth going for the Neo though.
Aftermarket pistons are different too and are often more expensive. There are some other different bits as well, intake side of things are slightly different so fitting other plenums / manifolds can be a bit more work.
There does seem to more and more Neo specific aftermarket stuff coming out lately though.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
