Hi everyone,
Just recently purchased a r34 gt-t coupe and im loving every second of it.
First things first was the remove the spoiler off it so i am seeing if anyone else wants it?
Its been named the shopping trolley wing?
Its red and all the bolts and screws are there with it.
Im asking as well pickup but for the right price i can post
Make me an offer!!
PM for pickup details :)
https://www.sau.com.au/forums/topic/401879-r34-gt-t-altia-rear-wing/
I have no idea what they are worth? but i want something fair! lol
Was thinking around $700? pickup or i can organised delivery
Gotta be patient with me as im only new to all this haha
I am located in Coffs Harbour NSW :)
  • 2 months later...
  • 4 weeks later...
Didnt know how to upload a image so have just provided a link.
Location is now gold coast area too.
http://imageshack.us/photo/my-images/694/20120919221050.jpg/
Plz let me know if the link doesnt work.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
