i thought we were comparing the wire-in ECU's? if so, both do low impedance injectors, so to the OP, no there is no difference in that regard. And i don't think e-throttle is going to be an issue for you, but i haven't checked if the xtreme can handle e-throttle.
  • Replies 100
The board in the G4 Plug-in storm is the same as the board in the xtreme, but the g4 storm wire in ecu is different,and only has 4x injector drives,so if your running a G4 storm wire in on a 6 cylender then you can only run the injectors in batch fire.
Yes, keep it to the V88 and the Extreme. All others are useless to me.
No i dont need electronic throttle, i've deleted it on my NEO. Track control pfft, Load dependant boost control solves that issue.
I'm driving Xspurt injectors which are 12 ohms anyway. No problem there.
Guilt_Toy.
You tune both of these ECU's a lot by the sounds of it. A few questions.
What i'm doing is setting up my car so that the ECU reads all sensors, Fuel pressure, Boost Pressure, Oil Pressure x 2 (1x at the oil pump and 1x at the engines main gallery, Fuel Temperature, Oil Temperature, Coolant Temperature, IAT etc.
Now what i'm wanting to do is set up the ECU to switch on or off outputs depending on the above conditions versus another condition.
IE. RPM vs Oil Pressure (oil pump sensor) . If oil pressure is 25 psi or above @ 2,000 RPM, condition is normal. (I'll have several points mapped accross the rev range - IE 4,000RPM - 50psi oil pressure and so on). IF the oil pressure drops below its set point at given RPM then an output on the ECU will fire, enabling a warning lamp and the accusump's electronic valve (preventing oil starvation). Also if RPM is below 300RPM, the output is always on (For engine pre-lubing via the accusump).
The second oil pressure sensor will be the same as above, apart from the fact i'd have it switch a different output or cut the engine, or rev limit. Something along those lines.
Another setup i'll be doing is Boost pressure vs Fuel Pressure. Ratio will be 1:1, for instance if i have a boost pressure of 20PSI, i should have a fuel pressure of 63.5PSI, if the fuel pressure drops too far at this level i would like to have the ECU go into rich and retard. Can these both do rich and retard?
I'll also be doing a few other tricky bits and pieces, but these two are the big ones i want to get under way.
Can they both do above?
Just to clear the air;
from the link website:
History:
Link was one of the very early market entrants twenty years ago. 2010 witnessed a turn-around in the market perception of the Link name thanks to the technical excellence of its product. The launch of the ViPEC brand has seen a new product pitched against high end competitors with outstanding results. Continued clear and unambiguous differentiation is further required to propel the ViPEC name higher
<p>
<br>
Just to clear the air;<br>
<br>
<span style="color: #282828"><span style="font-family: Georgia,">from the link website:</span></span><br>
<br>
<span style="font-family: Georgia,"><span style="font-family: Arial, Helvetica, sans-serif"><span style="font-size: 10px;">History:<br>
Link was one of the very early market entrants twenty years ago. 2010 witnessed a turn-around in the market perception of the Link name thanks to the technical excellence of its product. The launch of the ViPEC brand has seen a new product pitched against high end competitors with outstanding results. Continued clear and unambiguous differentiation is further required to propel the ViPEC name higher</span></span></span><br>
</p>
who is going to propel vipec to great heights now since ray has retired and dirtgarage is banned ?
Edited by Walk510
Still laugh about how hard dirt pushed vipec thrashed the rest then ended up with the gold box anyway. I guess the superior idle didn't matter on a drag car after all. Anyone know if his rebuilt the mercury 34gtr 26 recently? Lol
Edited by Ryan1200
Motec has been the ecu for many motorsport applications but the Link G4 Extreme is now being used by the new NZ Supertourer series:
http://www.linkecu.com/newsfromlink/v8-supertourers-are-go
The M84 is a versatile, race-bred ECU that is suitable for a broad range of high performance applications, including engines with up to 8 cylinders. It also suits rotary engines with twin, triple or quad rotors.
This new, entry level ECU is based on the advanced technology in MoTeC's benchmark M800, with a package of features to suit more moderate system requirements. It includes on-board Wideband Lambda plus 512 kB of data logging memory as standard.
Now with Nitrous Injection and 100 Hz max logging rate.
Install it as a stand-alone ECU or as part of a complete motorsport-ready engine management and data acquisition solution.
and about $2500
<p></p>
I'm sure Paul would love to continue his crusade if the mods would reinstate his account...hell, that la bumba idiot's been hit with the ban stick about half a dosen times and his still on here.
But i dont know the history and that decision is for the mods....now back on topic..
Guilt_Toy.
Interesting ideas. If this can be set-up, i'm sure guilt toy knows how to do it, but have you spoken to your tuner directly as to whether they are confident to do it?
Also, have you considered the haltech - from memory it has accepts all of those inputs, although its a little pricey aswell.
Edited by wedge_r34gtr
Huh, Paul from Red R Racing (swiper the fox) has been banned on here? What the??
Haltech, meh, my tuner says they are limited with what they can do, limited inputs and outputs.
He said for what i want to do, they are too limited and not configurable enough.
A few of the track RB30s have the Link watching for lack of oil pressure. I bought a high quality 0-150 psi pressure sensor from Rips (they are widely available) and my G4 will be loaded with minimum oil pressures for each gear and cut the engine if they are not maintained. There was a video on U tube of a GTST with an RB30 and you could hear it stuttering at a couple of points at Hampton Downs as the oil surges away from the pickup. No doubt it can be made to switch an accusump. My plug in G4 has spare inputs - The wire in Extreme will have more as well as more computing power.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
