  • 4 weeks later...
  • Replies 77
Quick question regarding mounting the digital sensors...
Do they need to be mounted in the exact centre of the car - or at least in the exact same spot as the original sensor?
Also curious about this.
anyone else had experiences with these units?
  • 2 months later...
  • 1 month later...
  • 4 months later...
You will have to do some research for current info
I understand both brands do a standard and a higher tweaked unit. (they are likely the same unit/technology if you see pictures of both side by side, maybe a different colour casing)
Also look at the capabilities of the ETS Pro? before rushing out and buying a unit.
Yep I'd hold off.
I bought the Midori one and - though it's been back to Midori for testing - found it to at least be reporting a fake signal to my V-Spec's digital G display.
Nissan G-Sensor:
http://youtu.be/Ct5od-3hSXA
Midori Spec Digital G Sensor
http://youtu.be/RHpTvkDVq8s
Although they aren't driven the same route - you can see that with the Midori unit in place the G display is shunted to the left whenever the vehicle is in motion.
I'd love some advice on this issue if anyone has any!
  • 1 month later...
What you see is how they work. I make the Skylab Fusion digital torque split controllers in the UK.
All these units so is tweek the voltage coming out of the G Sensor. Well, thats a simplified version.
What you see on the screen related directly to the voltage output from the G sensor. When the dot is in the middle, the G sensor is outputting 2.5 volts. 1.2G is 0.5 or 4.5v depending on direction. The usual ratio is linear. What my controller does , and all the others is alter the relationship between actual G and what the ATTESA sees.
This is why you cannot use them accurately with the R34 Display.
Just doing a price round up as I previously mentioned my attessa unit is busted and I need a new one:
Tarzan G Box - $ 648.65 - http://www.nengun.com/do-luck/tarzan-g-box
Midori Digital - $ 560.48 - http://www.nengun.com/midori-seibi/midori-spec-digital-g-sensor
ETS Pro - $599 - http://www.full-race.com/store/r14-awd-skyline/ets-pro-center-diff-torque-split-controller-for-r32-r33-r34-skyline-gt-r-1.html
Am I missing any? Haven't found any more info on Ruzic's G Sensor replacement. Is there any difference between these three?
These are all 100% OEM replacements?
Skylab Fusion $420
[url=http://www.gtr.co.uk/forum/175702-skylab-fusion-e-ts-controller.html[/url]
Firstly - THANK YOU.
You've been the only person (including Midori Seibi) whose been able to answer my question!
So, to confirm, the jump to the left is purely a miscommunication between the G-Sensor and the MFD, caused by an increase in voltage by the Digital Sensor and not a fault.
If that's the case you've made this old man very happy and very relieved!
THANK YOU AGAIN!!!!!!
Yes, there is no error, its just the way it works. What you have experienced with Midori Seibi is an unwillingness to be co-operate with the seller. They know exactly what their controllers do and what their short comings are. All controllers that work this way will have this effect. What you can do it leave the original G-Sensor wired just to the MFD. That way the G you see is accurate and the controller can still work.
  • 1 year later...
A quick update to this thread, I ended up getting a Do-Luck DTMII and blew it up trying to wire in the throttle cable :cheers:
Now I'm the market again for a g sensor. Is there any new products on the market? The Skylab looks interesting, anyone got one?
Is it PnP?
Er huh?
Don't get it? I replaced my one with the Tarzan G-Sensor and the display is now working A-OK
No extra wiring needed...
Maybe it's an update but the new unit I have works fine with the display.
Out of interest, how did you wire it for it to fry itself?
Is it PnP?
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
