Hi all,
I tried to go to the introduce yourself section of this forum but it comes up with an error msg. So seeing I joined to talk about & find out about Stagea's, I thought I would introduce myself here.
I once owned a 93 Skyline R33 sedan and loved it but it had some issues (bought it from a dodgy import dealer) so I got rid of it, then after the next non grey import and too much attention from the fuzz I got into four wheel driving to slow me down etc. So after a long time my love for fast cars has come back & now I'm a dad I needed something practical like the 4x4 but something to still enjoy and admire. Enter the Stagea....I just bought a low km series one auto Stagea RS4 AWD with Hicas :unsure: (Already looking at Hicas lock out bar)
So I have a few questions that I couldn't find exact answers too:
1. My Keyless entry doesn't work?, (I replaced the battery as I'm the first owner of this car in Australia)
2. Where can I get a workshop manual in English? (PDF format is fine)
3. Do these cars have a factory immobiliser?
4. Do Stagea's use OBDII diagnostics as I have a Scan Gauge II from my previous vehicle?
5. Where is the plug for the above?
Thanks for any help, it would be much appreciated.
Welcome, you will find answers to most of ur questions if u use the search function, just have to do a bit of reading. Just saying this cause ppl usually get flamed for asking question that hsve been answered a million times before, the answer to ur keyless entry should be in the stagea diy section
I did do some searching but maybe not enough....thanks for the heads up!
Welcome, Nice stagea, The Stagea's always look the best with the dayz front bumper.
I like this body kit, the side skirts are a bit damaged though by the previous owner from Japan.
Hi
should be able to find workshop manual on ebay, no factory immobiliser.
I wouldnt put a hicas lockout bar on unless you get an aftermarket ecu as it will cause the stock ecu to think that your hicas is failing and may cause more ecu issues than its worth.. Thats the advice my mechanic gave me and he should know as he had a Stagea and did so with his...
Hi
Thanks, I'll check out Ebay for the manual & thanks for the info on the lock out bar, but I already bought one.... Now I'll have to sort the ECU out, it never ends with modifying does it :rolleyes:
Just ordered the manual from ebay, thanks bjd. Where should I get a immobilizer fitted in the SE Brisbane area? I want to search the DIY section, but each time I get an error or it kicks me out back to the main forum page.... Moderators help needed!!!
A lot of info seems to have got lost/become inaccessible since the last revamp of the Website.
So far as I know the workshop manual has not yet been translated. There is an owner's handbook available. You can find R33 manuals online which take care of most of the mechanicals.
Does your central locking work? There is a tutorial on how to tune your key to the car but maybe the receiver is faulty.
The ecu is accessible via Nissan Consult not OBD - there are a number of aftermarket devices such as ecu talk
http://www.ecutalk.com/
that give you access mainly on a read only basis. The plug is behind the coin holder to the left of the fusebox.
HiCas delete should be the same as for the R33 so have a look in the skyline section (hopefully that is not broken too) and there are tutorials on getting rid of the hicas.
Thanks Kiwi,
I ordered a CD service manual off eBay today...
It's a shame all that info isn't accessible as its one of the reasons I joined this forum. Is it going to be fixed?? The Hicas lock out bar details have been explained to me. I will try searching the Skyline section for the other issues... Thanks again!
make sure you check the threads for the latest qld Stagea meet: confirmed for Sunday 24th June: would be good to have you along...
Thanks for the invite - I'll try and make it, but the day before the Stag is in the workshop getting coilovers, tie rods & Hicas lock out bar fitted. So hopefully it all goes to plan!?! Edited by Troppo
I'm in Brissy & have Nistune consult cable & software, I can come round & give you a hand if you like?
Thanks RB Bluey, if I can't get the central locking working I might take you up on that offer...
consult won't help with the central locking
it has probably had an aftermarket alarm/immobiliser installed at some point and they may have cut something
i'd be getting an adr compliant immobilizer fitted anyway as justcar won't insure you without one and most places give you a discount if you have one fitted
technically not correct, they will still insure you and take your money, but if it's not installed and you try to make a theft claim they will turn around and say no because it's one of our conditions that it is fitted. i really should get round to installing one in mine someday. :unsure:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
