everyone is to busy these days! where rhe f**k is evrryone?!
im looking at tyres and dunno if I should go ku36 kumos or 595 rsrs.
im leaning towafds kumos. there on the car now and seem good?
i have kumho ku36....
stick with those i reckon.
Was thinking this place had turned into a ghost town
Does Matt run RSRs on his car?
My advice is go with the Khumos
Got them on the front of mine and new or old, hot or cold they stick to the road
looking around it seems the ku36s are cheaper by around 30 bucks a wheel? the price between them doesnt bother me i just want the better one between the two, dont really care how they perform on the street for comfort or anything like that i just want a good track tyre thatll last heaps long etc. ive read around and ku36s will last longer so idk, i dont think anyone really knows which is better because theres probably next to no different haha
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
