i'll be dissapointed if you dont win then!
will be good as you'll be able to use all your power, nice and fast run.
Haha if you see the competitors... You will be dissapointed as i will not be winning lol :yes:
And as for ALL my power.... Mmm not sure about that either :laugh:
all issues sorted for your car now?
Lol you know that will never be the case! But i am killing them faster than they are appearing which is good ;)
good to hear and fingers crossed for you... hopefully get the evo ready soon and come out with you to a day... within 3 months would be nice, but just decided im going to recladd the house today, so more money gone ha.
Look forward to it mate!
All you north guys come and support the club will be an awesome event
The more cars we have come and say you are with SAU (free entry if you do) the more points we get!!!!
Oh and plenty of gaaaaaaaaaaate will be there too ;)
I'm heading up on Sunday, leaving from Thornleigh McDonalds and will be stopping at the Truck stop/Hungry Jacks at Beresfield, should get to Beresfield between 7:30am to 8:00am, so if anyone wants to head up together, my plan is in the NULON thread
Yep :yes:
Nice one mate, i have a mate that will probably tag along!
Does anyone in Newcastle have either an external gate GT30 turbo or a 6 Boost high mount manifold I could borrow to dummy up on my engine. Or even someone running a 6boost and Gt30 that I could just have a quick look at their car to compare. Can provide alcohol or similar for your trouble :)
Thanks
any of you guys gurus with N16 Pulsar? Car was running fine then when we tried to start it it wont even turn over. Theres a just a click sound coming from starter and the seems like all the power goes after attempting to start, dont even have hazard lights. Tried jumpstarting and using a jumper pack to no luck, battry has the green indicator on meaning its still healthy. Seems a bit like an electrical problem. Any ideas anyone?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
