Hey guys, I've had a vacuum leak problem or what I think is a vacuum leak problem for quite some time. My engine sometimes hunts, mostly when I take the key out and the turbo timer kicks in. One time I drove out the carwash and my engine was hunting real bad almost cutting the engine and when I put the foot down it just went CHUG CHUG CHUG and struggled to get up to speed with ALOT of fuel spitting out the back. I've ziptied alot of the small hoses coming out of the intake manifold(A 4mm or 6mm line on the back of the manifold allowing my gauge to read something and all hoses that size out of the manifold). I've only worked on marine diesel engines so I have no clue what to look for or what i'm even looking at too be honest haha.
Here's what my gauge reads normally and I would think its meant to be right down on the -7? I'm not 100%
Also i've found these stains on this hose coming near the front of the manifold, the side closest to the rocker cover but I never realised fluid even went into the intake manifold but there is a tiny coolant leak around this area somewhere too I can see a few drops on the block underneath it.
And this screw here(Pipe leads into my radiator) is damaged and not tight but again I don't know if it's even a problem
If anyone could help me i'd be extremely thankful as I have a feeling i'm losing boost pressure due to this aswell and my fuel consumption is effected.
Thanks!
-Joe
EDIT:
Edited by Jo33
https://www.sau.com.au/forums/topic/402576-cant-find-my-vacuum-leak-help-pics/
sounds like a few problems you have there! the car wash misfire sounds like water on the ignition system, have a look at your coils and plugs and check if water is / has gotten in there
Edited by StevenCJR31
That earth wire is the main ECU earth. VERY important
Also clamp off the big tube that goes to idle air control. The engine should stall. If it doesn't, you've got a vacuum leak at the charcoal canister. Delete it to diagnose
Lookin gat your vacuum/boost guage......that is a completely normal idle vacuum. You will never see -700mmHg. Usually halfwayish between 350 and 700.
The coolant is normal. There is a coolant blled screw right there (I think it's the 10mm one on the edge of your circle. Open it to bleed, coolant drops out. Normal.
Thanks for clearing that up, I've never seen boost pressure measured in mmHg always psi or bar so I didn't know what to expect.
Thanks for all the tips guys once I get home tonight i'll pick up all the gear I need on the way home and hopefully the hissing noise and hunting stops :D
It may have something to do with the turbo timer. Try leaving it idle without the timer on. Just leave key on. If it doesnt happen then its the timer
Id agree with that too. The turbo timer in mine used to make the car revs dip every time it beeped as it counted down. Never figured out why and couldnt be bothered unwirng it so just turned it off and hid it haha.
Edited by gotRICE?
It's called cheap install
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
