  • Replies 124
Posted Images
Thank you for the PM's. Reason for doing it that way is so I have numbers all in one place rather than spread over the thread. I will book it this Saturday. for 25 however if 25 don't turn up thats fine and if more want in we can add them up until 24 hours before.
Hey Guys,
My Daughter takes delivery of her Scoobie the day before the cruise and is keen to come along.
Would it be ok to increase my attendence from 1 to 2 and come in her car? We can't bring both cars.
Thanks...
Bob.
PS: That horrible gear knob is gone....OEM in transit, hopefully here by next week!
Cold air intake that is missing is also in transit and stupid BLITZ R-VIT Multi Function Infometer is coming out.
If anyone wants it that can have if pretty cheap.
No problem that brings us to 18... I dont see it reaching 26 so more elbow room at the table! Can bring the Scooby to.
Hate to be the arsehole to say this but I do expect best behaviour lol. We are not a pack of wild animals and although Bells Line is a good road for some spirited driving it is well patrolledby Highway Patrol so by all means go overboard at your own risk. It is a cruise which is to be enjoyed by all, there are track days coming up so if u want to give ur car a thrash on every stretch of tar go there.
Only a week away from good food and a good drive.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
