hey guys i thought i would share my story with you all, therefore am starting a build thread
A little bit of background of the car, ive owned the car for only 3 months, this used to be my friends car for over 7 years so i know everything thats been done and how its been driven.
he has originally build the engine, well at least he thought he had but he got a bit shafted, both of us found this out when the engine failed and i pulled the engine apart.
car mods are
rb30
25 neo head
mild cams not sure on the specs exactly but the way it idles it would be somewhere with the 250-260 duration with a lift of 8.9 (which ive calculated)
NO VCT used
GARRETT gt3788r turbo
3inch exhaust with twin mufflers,
turbosmart hyper gate 45
Haltech plug in platinum pro
PE 850cc injectors
nismo adj fuel pressure reg
walbro intank pump with 044 external + surge tank
greddy copy intake manifold ported and machined for perfect fit
trust intercooler
ill upload a few photos and keep you all updated of the future build that am going to do over some period of time
Ive made 320rwkw before the engine let go :( but you dont expect stock pistons to last much at that much power
Edited by bokee
This is where it all started when i bought the car of a mate,
this is how he had it set up
the red inlet manifold and plenum with standard throttle body is now for sale, asking 150 and pick up from syd liverpool
So ive decided to buy a copy greddy inlet manifold and a surge tank with bosch 044 of another friend,
ive painted the rocker covers in wrinckle black and turbo in matt black
also added a oil catch can
after fitting it all and runing in a small problem with the copy manifold and vct line which wasnt used, we managed to grind off a bit and still retain the vct aftermarket line, in case i decide to run the vct. :)
here what it ended up looking like :)
to me much nicer :P well am a sucker for black lol
Probably should chuck this up in the builds section. Lots more people who are building similar things hang out there and can give great tips.
Love the look of a tough high mount
Good numbers as well
oh shit i just realised its in the wrong thread
not the biggest computer person is there a way of just transferring it to build ups or just start another new topic with copy paste thing
With any luck a mod might move it for you
so one day i noticed that my car had a different cranking sound i let it go for a week or so didnt think of it much at that time, i honesly thought the starter was on the way out, but when i noticed that my oil catch can was half filled with oil i realised that something was not right, it was either excessive blow by engine not breathing properly so i went and checked that it was breathing properly. it all checked up alrite i went to check the compression it was dead even in first 4 cylinders of 180psi of pressure i thought to myself oh ok the engine is good but when i went to check it on 5th it only had 65psi of pressure, ohhhh shittt. the hunt then started for the failed cylinder 5 :(
started pulling things appart
inlet manifold off
rocker covers off
manifold and turbo off
it was getting preety late so i called it a night
If anyones wondering y am doing everything on the car is that i didnt have an engine crane at the time, i sold my old one ages ago thinking ill never need it again and here i am lol. ive ordered one but had arrived a bit too late.
so the next thing to do was to take the head off to see any physical damage that could be seen in a cylinder bore, head or piston.
when i took the head off i didnt see much at all except a bit of oil in the troubled cylinder
post-46081-0-42458400-1340009806_thumb.jpg post-46081-0-20694000-1340009914_thumb.jpg post-46081-0-98402900-1340009929_thumb.jpg
post-46081-0-23756200-1340009952_thumb.jpg post-46081-0-80348700-1340009976_thumb.jpg post-46081-0-90773700-1340009992_thumb.jpg
post-46081-0-20458800-1340010010_thumb.jpg post-46081-0-89004700-1340010026_thumb.jpg
im guessing your expecting to find it wasnt built after all?
hope it turns out to be a monster tho :D that turbo should be huffing over 400kw with ease
after pulling the head off first thing i saw was the piston design and it made me wonder the same thing, at the end it wasnt built well it was but with standard items
well since i still didnt get my crane i had to do it the hard way, i just shouldve gone to another shop that had one in stock but oh well :(
yep thats right take the piston out and see what the drama is.
when i took the piston out i could clearly see a couple of things, first the ringland of the piston has cracked/broken and the second they are stock rb30 pistons hmmmmmmm
sniff sniff you smell that?
Bullcrap
heres a few photos :)
ohh yeah
am sure many of you can confirm that these pistons are standard
genuine rod you cant really tell if its been shot pined or not :(
the only thing that has been changed was the rod bearings, ARP rod bolts and arp head studs
maybe the engine was freshend up with the ACL rb30 kit which u can pick up for around $800,
I measured the cylinder bore and it was standard :(
ive been told today that it was definatelly forged, the workshop that my friend got it off got it off of another guy whos originally built it, if this makes sence so basically workshop has bought this block of the X guy and then sold it to my friend thinking that it was properly build but anyways am starting to confuse myself :/
ARP rod bolts (good stuff) :)
rod bearing
post-46081-0-36563700-1340011388_thumb.jpg post-46081-0-23631000-1340011400_thumb.jpg
cylinder bore
it measured exactly 86.00 the first time i measured it indicatind it definately hasnt been honed :(
And final update for today is that ive ordered a forged rebuilt kit from spool imports
this kit is with the h beam rods but i upgraded and went with the I beams in case i decide to go over 450rwkw
cant wait until i start building :)
Also the workshop that had sold my friend the engine (my engine now) said to send him the block back and he shall put forged pistons and hone the bore, event hough he said hes gonna do all that i still went and bought this kit, so after everything is done i might have a set of spare pistons and rods :)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
