Hay guys i dont got no skylines but looking at upgrading my brakes on my 180sx :) its 4 stud and iam thinking of getting 300zx rotors from DBA pre drilled to 4 stud get some z32 calipers at the front and maybe Z32 master cylinder, i still dont know weather its a benifit to change the master cylinder when i do a brake upgrade :D
also should i be doing anything with the back? rotors or just put some good pads?
will doing this stuff up my ABS system if any one can tell me :rofl:
https://www.sau.com.au/forums/topic/40299-got-brakes/page/2/#findComment-831021
thanks geoff, rang them today and got a quote for slotted fronts, plain rears and lucas pads (he says they're better than bendix ultimates and have 10degree higher max temp), all for $800 supplied, $920 fitted, but i want to spray my calipers so ill just fit myself ;)
https://www.sau.com.au/forums/topic/40299-got-brakes/page/2/#findComment-833711
nah your master cylinder will be fine dude
Ummmm i dont think so.......not familiar with a 180s braking system however i would assume that changing your brake calipers and leaving the exsisting mastercylinder would require some sort of proportioning valve
https://www.sau.com.au/forums/topic/40299-got-brakes/page/2/#findComment-834138
thanks geoff, rang them today and got a quote for slotted fronts, plain rears and lucas pads (he says they're better than bendix ultimates and have 10degree higher max temp), all for $800 supplied, $920 fitted, but i want to spray my calipers so ill just fit myself :(
Great to hear, although I am no fan of bendix, and have no experience with lucas, but am totally sold on the racebrakes stuff.
With the spraying, cleaning is the key element, as well as laying up a number of coats, but I then used a gas torch to melt in the paint as some cleaners will strip the VHT off onto the driveway.
https://www.sau.com.au/forums/topic/40299-got-brakes/page/2/#findComment-834155
racebrakes.. u mean lalor brake n clutch LOL
yer well i probably wont spray my calipers now, i cbf, ill wait til the holidays to do it properly and research into what paint to use etc, i wanna do em black just a nice gloss black so i guess that'd be one of the easiest colours to find
so yer off to lalor brake and clutch soon to get em to fit my new brake system :(
https://www.sau.com.au/forums/topic/40299-got-brakes/page/2/#findComment-834194
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • To what gain?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
