Hey, just wondering what the average amount of boost you can run (standard computer, 25 turbo, cooler, exhaust) before the car will hit fuel cut & not boost properly.
I’ve just installed a boost tee which is set to 14 PSI & I’m wondering if it’ll likely need adjusting to a lower boost setting.
Cheers,
https://www.sau.com.au/forums/topic/403035-rb20det-max-boost-before-fuel-cut/
rb25det NEO cuts out at 14-15psi. thats when mine cut out.
and at the 15psi mark, it will also go into R&R around the 5k rpm mark every now and then.
mine ran into 2 problems when i hit 15psi, it either cut out completely and it felt like i drove into a wall when the fuel cut out,
or the other problem was it just stopped accelerating past the 5k rpm (i could keep foot on accelerator but it would not go past the 5k mark), i think the R&R kicked in then.
The ECU decided at random what it problem it wanted to choose.....
so i replaced the stock ecu with a power FC and run between 14-16psi depending on the day
Pretty certain RB20s don't have a fuel / boost cut mechanism. Other than the ceramic wheel shattering if you consistently run more than about 14psi boost.
pretty sure you are right on this.
best thing is to put it on the dyno and see what is going on with the afr's to make sure it's not leaning out
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
