  • Replies 49
I find it really funny that you guys keep baging the VL but at the end of the day it dose have a RB25.. I would of thought that some one would of done the same kind of mods and would have a rough idea on the power I could get out of it.. I dont know the specs of the tubro as some one has bult it for me.... thats y i said a " custom" turbo. all i'm looking for is some help and thought this would of been the place to ask a RB25 question but all I get are some wankers.... cheers for nothing I guess
The VL but at the end of the day it dose have a RB25..
dose
ZTUTUTUTUTUTU
Being as blunt and fair as possible. A stupid question gets a stupid answer.
Why dont you stop being lazy and go slap it on a dyno? Custom turbo you say. Last time i checked there were a vast selection of turbos that could be strapped to a 25 giving a whole range of different power figures. If you were to com and say you have a 25 with garrett gtxxx running over 9000psi then we could help you. But your question is vague and has too many variables.
Once again go and do a dyno run, then you tell us what you got!
i think i know the custom turbo you mean, it's a turbo off a cappucino with a chrome front cover?
you, and they guy that did the turbo have no idea of spec? who could guess, i reckon 70kw, as it comes on boost the wheels will hit the housings and fly off
Edited by WMDC35
I'm pretty sure its a S15 frount housing with a .63 Garrett rear and some sort of Garrett core... all i can say about the core it the oil feed is a 2 bolt flange kinda like the oil drail on the stock one. and the water lines would not fit I had to make some new ones.
well its wilcox4700 from ebay he builds turbos and he has ripped me off a bit so I would say never get a turbo built from him as it took him 2 months to build it and he told me it was a replacment turbo so all the lines and pipes should hook stright up but this was not the case.. I had to make a intake and a outlet drill and tap for the oil feed and make water lines the only thing that worked was the oil drain.... so not really happy with him. I'll have a look to see if I can find any numbers and let you know
Wow...so...you assumed people have done similar to you...yet you didn't have the initiative to search the forums for threads that exist along the same lines? There's a thread in the forced induction section dedicated to dyno results...
P.S. It's "would have", not "would of".
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
