  • Replies 221
After reading a whole bunch of comments i would like to add this: Do you your research and you will discover that the iphone 5 is an S3 with apple stickers on it. Apple paid samsung to use their internals. Not to mention that the new screen technology is also owned by samsung. I'm not an Apple hater by all means but a company that sues another company because "If you squint and look from this angle it kind of looks like our product". Apple have the same issue many different companies are falling into. Same shit different smell. They don't innovate anymore. They match the current best product on the market, slap their OS on it and go "ours is better buy it" and people do. Also if you have been following apple/the news lately you will see that last week their shares droped 20% in one week. I think that shows that people are getting sick of the same thing over and over. Apple was dead when steve resigned.
iPhone 5 isn't quite S3 with Apple stickers, but thats almost what I was looking for: a S3 that was smaller, but didn't sacrifice power.
Processor in the new iPhone is a custom Apple design manufactured by Samsung, not a Samsung processor. Screens were all Samsung, now I think Samsung have been cut back, and its mostly LG and Sharp supplying screens.
All these wankers who think their iPhone is better than all the other phones are deluded. But they're pretty much a copycat of everything else now, which is scary. After years of offering phones that were based on 2-3 year old hardware, they've finally made something current. Imagine if they keep this up and do finally make something better?
Or maybe Samsung et al could realise that not everyone after a good, powerful phone wants a 5" screen, and start making smaller phones that don't suck more than Lindsay Lohan.
Yeah, I really can't go back to a smaller screen after having an S3. The size isn't even a problem 99% of the time. Plus, it's waaaay better for reading/browsing as you don't have to zoom as much, and you can hold the phone a reasonable distance from your face without squinting.
Seriously, phones have gone this way for a reason. Our needs are changing.
Battery life is horse shit however.
Thats fine, but my point is that not everyone needs the bigger screen. I have a tablet, why do I need a phone with a big screen as well?
Surely smaller screens need less power too?
the s2 isnt that bad.
and at least other manufacturers have other (current)models available.
the s3 has a small screen compared to the note2...
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
