I'm looking at getting a short shifter, but I can't seem to find a place to get them in Sydney (I'm probably not looking hard enough, but I've done my fair share of google searching lol)
Anyone know where I can get one for my r34 GT-T? I heard the japspeed short shifter kit was good, lots of guides on how to install it too- any others and where to buy them? I have no idea where to get the japspeed one though, because everytime I search it up, it always takes me to a UK site.
thanks!
https://www.sau.com.au/forums/topic/403261-short-shifter-advice/
ha, it's in the throw not the lever length
yeh that's what i was thinking. a short shifter usually has the same length as the original shifter right? The difference is the pivot point which reduces the throw.
Anyways, anybody know where I can get one?
eBay, just jap. Lots of places. I had a spare so I made my own. Just cut the threaded part off, got rid of the rubber filled top section and welded the threaded part to the inner section of the shifter. I wanted a solid shifter with a bit less length so pretty happy with it
short shifter has the same length lever but needs to be moved a shorter distance to select gears
Yeah pretty much this. I've seen the eBay ones and they basically raise the pivot point so less throw is needed
The way I described above doesn't decrease the throw just decreases the length of the shifter. Gives the illusion of a shorter throw basically
so a shortened factory shifter would serve the same purpose (?) as the pivot point would be difficult (at best) to change?
  • 5 years later...
In layman's term. The gear/shifter handle lenght is relatively the same as stock, but the movement required to change a gear is less than a stock. Cutting the lever doesn' t mean its a short shift it just its a short lever same shift.
I mighy be wrong in the following but I belive the 34 Gtr comes with one and the Tomei Chaser too comes with a short shift.
  • 1 year later...
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
