  • Replies 90
Back on topic - my personal fav: Early Oral Intervention! I'll take two to go please!
Acronym Definition
EOI Escuela Oficial de Idiomas (Spain, Official Languages School)
EOI End of Image
EOI End of Interrupt
EOI Escuela de Organización Industrial (Spain)
EOI Evidence of Identity (various nations)
EOI End of Input
EOI End Or Identify
EOI End of Instruction (type of exam)
EOI European Ombudsman Institute
EOI Equivalence of Input (telecommunications regulation)
EOI Earth Orbit Insertion
EOI Elf Only Inn (webcomic)
EOI End of Identity
EOI End Of Installation (US Navy)
EOI End of Item
EOI Electronic Order Interface
EOI Early Operational Interface
EOI Executive Office Installation
EOI Engineering Operating Instruction
EOI Effective Operating Income
EOI Early Oral Intervention
EOI Evidence of Insurability
EOI Extra Ordinary Income
EOI Explanation of Investment
EOI Emergency Operating Instruction(s)
EOI Export Oriented Industry
EOI Electronic Operator Interface
EOI End of Irradiation
EOI Effect of Interest
EOI Every Other Issue
EOI Evidence Of Insurance
EOI Expression Of Interest
EOI Electro-Optical Interface (Nortel)
EOI Engine of Innovation
EOI End of Innocence (music album)
EOI Export Oriented Industrialisation
EOI Embassy of India
EOI Exchange of Information
EOI Edge of Insanity
EOI Economic Opportunity Institute
https://www.sau.com.au/forums/topic/403435-eoi/page/3/#findComment-6417275
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
