NYTSKY Posted June 26, 2012 Share Posted June 26, 2012 Hi all, Having snapped my shafts like twigs on the weekend im looking for options to upgrade. I have a friend who tried billet items from the US but snapped them also. Should I just keep putting stock ones back in and see how I go? What have you done? Bought? Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/ Share on other sites More sharing options...
The Dan Posted June 26, 2012 Share Posted June 26, 2012 What were you doing at the time? Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6416359 Share on other sites More sharing options...
NYTSKY Posted June 26, 2012 Author Share Posted June 26, 2012 At Sydney Dragway. I got 1 run lol Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6416376 Share on other sites More sharing options...
skylinecouple Posted June 26, 2012 Share Posted June 26, 2012 Just because someone snapped the drive shafts from the States doesn't mean you will. They seem to be reasonably priced. Go for it. How old were your drive shafts by the way ? Original ? Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6416383 Share on other sites More sharing options...
The Dan Posted June 26, 2012 Share Posted June 26, 2012 Are you snapping the half shafts or the driveshafts? If you are snapping the half shafts, modify the way you drive. We have guys that run low 9's on standard diffs. If you just roll up, limiter and launch then you are going to always break shit. If you roll up, handbrake on, preload the driveline, handbrake off and then limiter launch, you will probably save everything Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6416396 Share on other sites More sharing options...
NYTSKY Posted June 26, 2012 Author Share Posted June 26, 2012 Half shafts and possibly the planetary gears in the diff. I didnt launch the car as I was just feeling out the traction, its axle hopped twice just after I left the line then bang. Ill be putting stock shocks in the rear and getting I higher profile tyres but want to see if there any worthwhile options for the shafts. Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6416413 Share on other sites More sharing options...
sydking Posted June 26, 2012 Share Posted June 26, 2012 How much power ur gtst making? Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6416517 Share on other sites More sharing options...
NYTSKY Posted June 26, 2012 Author Share Posted June 26, 2012 800hp Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6416580 Share on other sites More sharing options...
sydking Posted June 26, 2012 Share Posted June 26, 2012 ive seen a few carbon drive shafts pop up. If your going to keep breaking std then may be worth the while. std gear box? Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6416593 Share on other sites More sharing options...
NYTSKY Posted June 26, 2012 Author Share Posted June 26, 2012 Might just throw some stock ones in for now and try again. Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6416603 Share on other sites More sharing options...
turboedsloth Posted June 26, 2012 Share Posted June 26, 2012 link to billet driveshafts by any chance? Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6416639 Share on other sites More sharing options...
NYTSKY Posted June 26, 2012 Author Share Posted June 26, 2012 http://www.moserengineering.com/axles/custom-alloy-axles.html Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6416664 Share on other sites More sharing options...
Simon-S14 Posted June 26, 2012 Share Posted June 26, 2012 do you have a GTR rear end? if not then do that Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6417031 Share on other sites More sharing options...
NYTSKY Posted June 26, 2012 Author Share Posted June 26, 2012 Was thinking about that but means new or modified rear shocks and throwing away some gear that I want to keep. Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6417126 Share on other sites More sharing options...
Simon-S14 Posted June 26, 2012 Share Posted June 26, 2012 why? you can retain the current uprights and cradle. just get a GTR diff. halfshafts and hubs. remove the stock gear and then bolt in the new GTR gear. it all bolts in with ease. if you break GTR halfshafts you're really rough haha Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6417739 Share on other sites More sharing options...
The Dan Posted June 26, 2012 Share Posted June 26, 2012 I think its even possible to install the GTR centre into the existing R200 housing. Then all you need to do is bolt the GTR axles to the side and go do some launches. Internal widths etc are all the same from memory. I have a couple of diffs lying around the shop I could check but time is scarce for me during the day so you might have to wait a month for that info Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6418013 Share on other sites More sharing options...
Simon-S14 Posted June 26, 2012 Share Posted June 26, 2012 yeah crown wheel and pinion will fit in any r200 carrier pretty much. only issue is you need a GTR lsd Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6418303 Share on other sites More sharing options...
StevenCJR31 Posted June 26, 2012 Share Posted June 26, 2012 yep, use the GTR set up, one race team i read about break half shafts on a semi regular basis then tried using aftermarket shafts but they broke more often than factory shafts, thier solution was to use new factory shafts and change the way they launched the car (ie no axle hop) Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6418376 Share on other sites More sharing options...
sydking Posted June 27, 2012 Share Posted June 27, 2012 Rear subframes are all interchangable, Could you not just shim the diff to a cirtain spec. ive fit Gtr front hubs and also changed over the rear hubs on my GTS4, Through thats probly much more similar drivertrain to a gtr then a gtst would be. Though in saying that i did use gtst rear hubs and the axels are a straight fit. Link to comment https://www.sau.com.au/forums/topic/403441-drive-shaft-upgrades/#findComment-6418657 Share on other sites More sharing options...
