IT'S ON!
Thanks for being patient people.
Monday 6/8/2012
@ 7pm
Pioneer tavern, northern rd, penrith(next to john cootes) just off the freeway.
They have a full menu, bit Mondays are 2 4 1 chicken schnitzels.
24 schnitzels toppings to choose from.
3 sizes to choose from.(im a big eater, I get the small).
Jugs of softdrink are $9.50
I'm pretty sure the snitties are a et ound 25+....
I will be booking a table a week in advance.
It does get busy, and you will have to line up for your order.
Went there last Monday, and waited in line for approx 20mins, but they do get the meals cooked pretty quick.
Tables were packed, that's why ill be booking.
Please list in here if you're coming.
Anyone that can't confirm that far out, should be able to just grab a table.
Hope to see you all there.
Cheese, Luke.
  • Replies 57
August? That's, like, years away!
I didnt want it to clash with any other event.
This was around the best time, and it gives people time to organise.
I know how bad people are on here for that.
how farken good is schnitzel?
best i had was a pub in melbournes chinatown that had about twenty different kinds..also the gypsy sauce snitties at Una's german rest. in double bay, they have one near broadway called 'Essen'.
this place might push them off the totem pole though..
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
