Haha thanks Jay :P
that's pretty fcuking good for 1 second!!! Super steady hands right thurrrrrrrr!
A random shot from Shannons Nationals.
i was cheating tho, my camera is a range finder so I can look through the viewfinder. :P
it was a heap of fun tho so i'll probably give it a try again and see what I can come up with.
A DSLR would go black as its taking the pic which would make it heaps harder.
love the atmosphere in that shot
I like that landscape shot matt, good perspective!
i agree, point of view is awesome and the framing is spot on! only thing i would have done different is stand on the other side of the pylon. or maybe even standing closer to the camera, like on the rocks in the foreground, walking toward the bridge. man, wish we had stuff like that down here to discover.
did you change the aperture or shutter speed between shots?
Edited by Jay019
  • Replies 87
Posted Images
damn, too late to edit.
oh well... set up a rig for my scooter today :P
had a go at removing the pole and shadow. got the the tyre and gave up, i dont have the skills for that, haha.
its a monopod mounted to the rear rack. can still extend out further, but have to find somewhere with plenty of space and little traffic to try it out
Edited by Jay019
<p>You can't stand where you suggest because there's a big arse ravine thing there.<br />
Putting him right between pylons would have been rad for sure!<br />
<br />
He's close to the pylons to really emphasis how big they are. Those sandstone bricks are about 20cm high and 60cm long each. Needed the person to give it the sense of scale. The bridge is about 15 metres high i reckon, maybe even 20.</p>
<p>changed shutter speeds, changing ap will change sharpness. Only use Ap if shutter speed is paramount to what your capturing.<br />
<br />
What did u end up booming with?</p>
<p> </p>
<p>shot some water n stuff...<br />
7656287466_ca80aa4131_b.jpg</p>
<p> </p>
<p>7656578430_b54f8a0d7e_b.jpg</p>
<p> </p>
<p>7660619372_1115d43d11_b.jpg</p>
Edited by MaTBoY
^indeed nice seascapes man..
E-shoot before I flew to london:
Rest on my blog if you keen.
Gotta start editing my London wedding gig.. Took so many pics there :(
Can I just say that London DJ's are so much better than here. Their setups are so much more elaborate AND BETTER!!!!!!!
When I come home from a wedding here my ears are ringing from the shitty speakers. Over there the wedding had three different Dj's over the days and all three of them had awesome setups which took more than an hour atleast to setup. They all had atleast 4 people in the crew. Not at any stage did my ears ring or did I go deaf. Quality speakers thats for sure!!
I actually asked one of them how much their whole setup costs and he said he has invested 60,000 pounds!!!! Thats right 60,000 pounds. Anyways I will try and get some pics up from the london gig :)
Nice work Sidd, so are you back? I'm sure if you went around to a few parties and stuff you'd find more dj's would be similar to over here than that. Were they fully commercial dudes or what?
Anyway, I'm starting on the painted shots from the red silvia set. here's the first.
thanks man :) Appreciate it!
Kory, you've made me wanna head south. ALl the shots from P.I. look amazing! Shooting next to the ocean. not to mention the grass is actually green :P
Here's some a shot with some greenage. and NOT A CAR IN SIGHT!
lapston bridge if I'm not mistaken?
fun to absail at midnight....
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
