Due to parting out my car this engine is for sale seperately. Engine will be removed tomorrow or during the week.
It comes with HKS Forged pistons. This will be confirmed when the sump is removed for inspection. They are definently not standard as they don't have 5mm ish round raised circle on them when viewed though the spark plug hole. I imported the car with this engine in it. The spec sheet mentioned HKS pistons. This can be believed as everything else listed replicated what was on the car.
Engine has never had larger injectors fitted therefore has never exceeded 300rwkw. Everyone knows these engine will last forever when run under 300rwkw and boosted around 15psi with a good tune. I drove it with 280rwkw just to be safe as engine rebuilds are the nemesis of GTR owners.
I cannot confirm yet if it has a N1 oil pump or R33 crank. It may even be an R33 GTR motor? Rods are also unknown? Never saw the oil light flash or gauge drop due to surge.
Cams are standard and fitted with adjustable cam gears fitted.
Engine has never been overheated in my ownership.
Rocker covers and cam cover have been painted in 2 pack metallic silver.
All electronics/accesories attached to the engine will be included.
-5 turbos have limited km's with adjustable actuators. Willing to sell these seperately.
With these turbos I drove it for a year. After that the car spent a year EPA'd noise (was cleared) and then driven a few times the following year. Last 2 years it has been de-reg'd just sitting in my shed. Started occasionally.
Front diff/sump included.
If bought in the next few weeks with the turbos I'll throw in some custom made 3 inch dumps plus twin 3 inch front pipes merged to 3.5 inch pipe with 3 inch flange.
Happy to do a comp or leakdown test after removal. Sold the gearbox before I had a chance to check it.
Need to sell these. I don't want them taking up space!
Pictures will be added during the week not that what an engine looks like matters. Its the condition inside that counts!
$5000ono for engine and turbos. Can supply everything needed to do a GTSt conversion for a few extra dollars. I've done the conversion before.
Also have a OS Giken Triple plate clutch in great condition. Prob 90% meat left $1500 - These are $3000 new and never ever thought of slipping.
Located in southern suburbs of Melbourne. Happy to feight but please organise you own prices.
Edited by Rowdyr32
  • 3 weeks later...
Sorry guys. Forgot about this.
Engine has been just sitting in the car for months unbolted awaiting an engine crane.
Also I'm chasing $1300 for the turbos. Their in perfect condition.
Now there's a bit of interest in the engine I might lift it out over the weekend.
  • 2 months later...
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
