Hi Guys,
After searching the internet for options on upgrading my R34 N/A diff I stumbled across this thread:
http://www.skylinesaustralia.com/forums/topic/255275-r200-lsd-diff-in-r34/page__st__20
My 34 started life as a n/a but now has a rb25det in it from a 33 and running link ecu management. Link to my project thread here:
http://www.skylineowners.com/forum/showthread.php?t=164228
But anyway to the point of my posting :)
Is it true that a rear diff from a r33 gtst which is manual and has abs is a direct fit and upgrade on my current 2.0 n/a rear diff?
Since 2009 has anyone done any different diff changes that have worked better? Hope you can help or point me in the direction of where to find the answers :)
https://www.sau.com.au/forums/topic/404208-upgrading-an-r34-na-rear-diff/
I am not 100% certain as I don't get that many N/A cars through my workshop but from memory the tailshafts are different lengths which might make the diff lengths different. You will need to measure the length and width of the diff. If you can do that, I will (should) be able to measure a couple of R33 GTST diffs I have laying around and tell you if they will suit. Also a photo of your diff might help me remember the last one I did
I was pretty sure it was the back section that was longer. Distance from the gearbox to the centre bearing I could understand (even though the gearbox is only 3mm different in length)
But then again I see that many of the bloody things I could be off on the old memory department
From my research there are two differenf nose lengths on "short nose" R200s . The one with the cross wise sensor in the nose is about 3/4" longer than the ones without so for a bolt in I think you need one with that sensor to match your tailshaft length . The diff and tailshaft are matching pairs length wise .
The alternative is to remove your std diff assuming its ratio is right and swap the hemisphere for something better and get the side stubs to suit you inner rear joints .
A .
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
