  • Replies 142
Yeah that's right 89cal these boys are trying to tell me that a 02 can't cause a lean mixture and you yourself no they can but most the time they cause a rich mixture I've seen it right In front of my very own eyes I've even got a damaged 02 sensor with my right now that I can 100 % prove with make a rb26 run lean
Yes cause it reads way out of limits and runs lean mate I've tried as well :) you no yourself they can cause a lean mixture when cruising simple as that I'm Finished thanks for that
Edited by Hot33r8723
No I'm telling you it wont run lean enough to melt things. It wont let it go over 15.4ish:1 AFR till the ECU takes over and pulls it back.
I'm not sure how the GTR's work but I'm guessing 1 O2 sensor for each 3 cylinders, so you may end up having it drive weird at cruise or fouling plugs in 3 cylinders, but I honestly dont think it could run lean enough to melt things
I run 15.7:1 AFR's at cruise with no issues. Some days they even get up around 16:1 for whatever reason, and my engine is fine.
I think your problem might have been your fuel pump as originally thought....
Yeah gtr one sensor for 3 cylinders and if your air flow meters resistance is out of whack as well as a damaged 02 put them together and watch them
Front 3 fry away but hey 89cal your the first person ive spoken to that actually no what there talking about an yeah I never believed the o2 would cause a lean mixture I always thought rich cause it throws a code to the ecu an depending on how your afm reads Aswell can cook cylinders
Not exactly. The 02 sensors signals are halved by the ecu. Not 1 afm per 3 cylinders.
And with the 02 sensors im pretty sure the factory ecu is batch fire so it cant physically lean out cylinders unless and injector is playing up
But any way I've got a Walbro 255 now it's a bit loud in the back end what u think about the direct feed mod do you think it's
Worth it
Definately worth it. Wen u see the flow gauge before and after a rewire it the flow goes off the gauge when rewired
Is there any real benefit in doing this with a Nismo/Tomei fuel pump?
Been thinking about doing this for a while but not real sure if its worth it
Each airflow controls each 3 cylinders I don't know about the other pumps
How can the AFM's control each three cylinders when the intake joins into one pipe before it gets to the intake manifold?
Air metered through turbo 1 joins with the air metered through turbo 2 after the intercooler, so air from turbo 1 doesnt necessarily go to cylinders 1-3, it equally spreads between all 6
So what if I run the stock wiring and don't do the direct feed mod ???? The pump wouldn't run at full capacity right ? But a Walbro needs minimum 12 volts and there's a voltage regulator that ups the voltage when revs are raised about 3000 grand right ? So the pump would be working overtime doing the direct feed mod and as Walbro says minimum voltage 12 volts and the specs of the pump would have been tested minimum 12 voltage other wise Walbro would look ridiculous for making fake claims the best thing to do is purchase a hot wire earth kit for your whole car not just up the voltage to the pump
Nah man ur 100% wrong :rolleyes: ...... Sarcasm
On a rb26 the airflow meters are before the turbos mate senses the air
Flowing through the front of each turbo and signals is sent back to the ecu telling the ecu how
Much air is flowing into each turbo and each 3 cylinders I work for tony rigioly mate
Both turbo's end up flowing air to the one point. There is one intake manifold that joins all 6 cylinders
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
