  • Replies 142
Yeah that's right 89cal these boys are trying to tell me that a 02 can't cause a lean mixture and you yourself no they can but most the time they cause a rich mixture I've seen it right In front of my very own eyes I've even got a damaged 02 sensor with my right now that I can 100 % prove with make a rb26 run lean
Yes cause it reads way out of limits and runs lean mate I've tried as well :) you no yourself they can cause a lean mixture when cruising simple as that I'm Finished thanks for that
Edited by Hot33r8723
No I'm telling you it wont run lean enough to melt things. It wont let it go over 15.4ish:1 AFR till the ECU takes over and pulls it back.
I'm not sure how the GTR's work but I'm guessing 1 O2 sensor for each 3 cylinders, so you may end up having it drive weird at cruise or fouling plugs in 3 cylinders, but I honestly dont think it could run lean enough to melt things
I run 15.7:1 AFR's at cruise with no issues. Some days they even get up around 16:1 for whatever reason, and my engine is fine.
I think your problem might have been your fuel pump as originally thought....
Yeah gtr one sensor for 3 cylinders and if your air flow meters resistance is out of whack as well as a damaged 02 put them together and watch them
Front 3 fry away but hey 89cal your the first person ive spoken to that actually no what there talking about an yeah I never believed the o2 would cause a lean mixture I always thought rich cause it throws a code to the ecu an depending on how your afm reads Aswell can cook cylinders
Not exactly. The 02 sensors signals are halved by the ecu. Not 1 afm per 3 cylinders.
And with the 02 sensors im pretty sure the factory ecu is batch fire so it cant physically lean out cylinders unless and injector is playing up
But any way I've got a Walbro 255 now it's a bit loud in the back end what u think about the direct feed mod do you think it's
Worth it
Definately worth it. Wen u see the flow gauge before and after a rewire it the flow goes off the gauge when rewired
Is there any real benefit in doing this with a Nismo/Tomei fuel pump?
Been thinking about doing this for a while but not real sure if its worth it
Each airflow controls each 3 cylinders I don't know about the other pumps
How can the AFM's control each three cylinders when the intake joins into one pipe before it gets to the intake manifold?
Air metered through turbo 1 joins with the air metered through turbo 2 after the intercooler, so air from turbo 1 doesnt necessarily go to cylinders 1-3, it equally spreads between all 6
So what if I run the stock wiring and don't do the direct feed mod ???? The pump wouldn't run at full capacity right ? But a Walbro needs minimum 12 volts and there's a voltage regulator that ups the voltage when revs are raised about 3000 grand right ? So the pump would be working overtime doing the direct feed mod and as Walbro says minimum voltage 12 volts and the specs of the pump would have been tested minimum 12 voltage other wise Walbro would look ridiculous for making fake claims the best thing to do is purchase a hot wire earth kit for your whole car not just up the voltage to the pump
Nah man ur 100% wrong :rolleyes: ...... Sarcasm
On a rb26 the airflow meters are before the turbos mate senses the air
Flowing through the front of each turbo and signals is sent back to the ecu telling the ecu how
Much air is flowing into each turbo and each 3 cylinders I work for tony rigioly mate
Both turbo's end up flowing air to the one point. There is one intake manifold that joins all 6 cylinders
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
