  • Replies 142
On a rb26 the airflow meters are before the turbos mate senses the air
Flowing through the front of each turbo and signals is sent back to the ecu telling the ecu how
Much air is flowing into each turbo and each 3 cylinders I work for tony rigioly mate
I'm over it mate stuff it I've had enough now
Tony rigoili aye. Didnt know they hired rappers.
And skylines don't take idiots like
Yourself and your shut down now so u can't talk my little NASA bathroom cleaner you work for NASA but are hired to clean the toilets ahahaha
Edited by Hot33r8723
Yeah yeah we hear us why so serious hahaha u look like a spastic retarted clown lmao more
Like why so delirious cos u don't no what ya on about ha!
Ummmm, thats Hugh Jackman as the joker.
Its ok, I understand, you cant interpret pictures with a iq below 30
Maybe if I put a afm on him then it might click
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
