hey guys just a quick question...
have this noise coming from my cam cover.
when its cold sounds a lil loud with revs around 1200/1300 rpm.
when i rev it goes away after 1600rpm and when idling at around 900/1000 can just hear it a little bit.
as it warms up it goes away at normal temp and goes away...
heres a video of it similar to mine or almost identical to be honest at the last 25 secs of video.
100% from the cam cover as i rember month ago tigtning those allen key bolts there and got extremly loud then loosend them and went away but its back again.
any ideas would be great or help on this as a few people have had this problem after reserching it but all different opinions...
Edited by R33ram
https://www.sau.com.au/forums/topic/404972-noise-from-cam-cover/
Yea mine has been making this noise ever since the timing belt was done but i had a entire kit installed bearings belt everything changed professionally now it makes this noise on a cold start and goes away once it's warmed up...
What's the worst case scenario is it something that should be fixed asap or??
Edited by Lethal_aussie
yours sounds like idler, if you are worried get the belt tension checked it could be too tight, if you installed a GATES belt and had it tension to stock spec it could be over tight.. worse case the idler gives way...
yea get it checked tommorow but hate taking it to mechanics as they are always like what noise lol
Is there any damage to be done or is it just a noise that gets annoying and no affect to engine besides that?
I did put a bit of wd40 or it got in there and became louder lol so most likley the cause is what you saying....
Yep was a gate's racing belt kit, if the idler gives away what will happen lol? Just not crank over or will it actually damage the engine on failure? If its just a noise i wont worry about it ... Was all done professionally so its all under warranty etc ill just blast the mechanic and they can cop the bill.
Besides the noise it does on idle on a cold start ... would it get much worse before that would happen or would it just suddenly happen? I had the entire gates kit done doesn't that include new idler's etc?? paid 400 bucks be damned if it was just the belt they replaced... regardless mechanic would be at fault anyways since they installed the kit and did the timing etc??
Did you supply the mechanic the parts or did they suggest the parts and source the parts? Warranty might not stand if you supplied the parts...
I installed the kit myself did the tension up and it was sweet, no noise or anything for a good year, recently i had to take the belt of and when i started the car it made that exact noise but much louder, i loosened the tensioner off and the noise has gone, im not worried that the belt will slip or jump and it was a Cu*t to even get off and back on again.
Next time i will just buy genuine Nissan belt as their is nothing is wrong with them..
Yea im thinking that to should of got nissan ... im thinking its kinda overkill for street use gates... yea they sourced and recommended the gates timing belt kit they go through justjap i think.. as it was stronger etc
I always pay for a professional to install and source everything as im mechanically stupid in most area's lol... short of a oil change etc
  • 4 weeks later...
*Just a update* on this guys, Had it checked again and the noise was the Timing belt which was actually loose.. and needed to be re-tensioned so all good now, cheer's :)
Hmmm
That is odd, how can the belt be loose?
I have exactly the same noise as you had, belt done months ago ..
Apparently the original mechanic that worked on my car was meant to re-tension the belt when i had the gates kit installed to begin with and didn't... The main mechanic "owner" said he had to redo the kit and tighten it as it was loose which is what was making the noise..
This is what i was told..
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
