  • Replies 57
Running in dyno pull at 20psi of boost pressure. Responding nicely
your dyno guy above is a splitting image of my brother - i shared this clip with my mates & we all had a laugh about it!
Enough said.
congratulations - 1430nm is absolutely massive!
my rb26/30 made 930nm on a dyno dynamics dyno - would it be accurate to say that your engine makes in the vicinity of 50% more torque? if so, i don't think i could even begin to imagine how this feels...
not bad Martin, i was expecting the turbos to come on later in the rpm
do you feel that power loss below 3800 on the road? does it feel light switch through the midrange?
Edited by domino_z
Domino, it shows to boost slower than it actually does as we needed to use a faster ramp rate on the dyno to keep full traction at all four.
In other words its not that much laggier than stock, with a massive seam of torque once its 'on'
Quite impressed with this combo actually :)
Saw this car on display on the weekend, looking good, cant wait too see it unleash down the strip! Let me know when its going to be down there Errol....
Cheers Cale
  • 2 months later...
martin, as you know we have been moving and no time to drive this vehicle. have now had the extreme pleasure of driveing about 300 kilometers and the more i drive it the more impressed i am by the whole package that you have put together for us. the torque is awsome to say the least and it comes on incredibely fast and furious. i will run it in properly over the next couple of months before heading to the local drag strip. the amazing thing is that even with this package the vehicle is quite driveable. thanks for all your help in putting this all together.
Make sure you let us know when it is going to the strip please errol
  • 2 months later...
Sure will Errol. Domino, in short Rooters car is a built Trust 3.8 engine with ported heads equipped with a TD06 turbocharger kit, Syvecs management, and all the fruit to make it run good power on E85 (2000cc injectors etc.) If you want a detailed, detailed list then let me know. Its a nice tight combo, and the TD06 kit is one of our favourites, as not only does it work well, but its engineered for RHD GTRs unlike most anything from the USA (big consideration that one if you dont want to spend extra money fixing steering rack clearance issues) :)
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
