Ok guys been che king out some other builds on here so thought id have a go at making one.
Car is a 92 r32gts-t. I picked it up just over a year ago with panel, paint and rb25 motor and box conversion completed already. The interior is pretty much stripped. Has no rear seats, just a sub and amp. Car is fully caged, just a bolt in job for now welded job to come later. Got driver and passenger velo fixed back bucket seats with Mona harnesses. Seats look awesome but god dam they are uncomfortable for someone my size lol.
I picked the car up a week before powercruise last year in bris so the only mod in that week was a set of 20's just to raise the height of it a bit. I gave it a quick fluids change then off to powercruise it was.
The main aim was to have some fun. First session friday morning the standard rb25 turbo gave up on me in a big way. The only replacement I could find was a standard rb20 item. So then it was down to 7psi for the rest of weekend. Still managed to have some fun and win some races just had to be a bit picky who I raced lol. Went in the burn out comp on Saturday night for a bit of fun but that's where my weekend stopped. Turns out 196hp on a sticky pad wasn't enough power to comfortably turn the rear wheels and my clutch had other thoughts on the matter. Weekend over.
So wat to do with a broken r32 now. A few ideas were tossed about but we decided to do let's do it once and do it properly. Quick budget was made up and looked reasonable enough. Its amazing how quick budgets get blown out of the water.
Motor is a 26/30 which I bought off a mate who unfortunately had his gtr written off by his ex gf. This motor came with approx 35000 in receipts and it has the best of the best in it. I picked it up substansially cheaper than that tho. Quick case of removing the sump to convert ro rear while drive use and check out the bearings and it was all systems go. It was only a short motor so had to fund my own bolt ons. Stole wat I could off the 25 then hitnebay, big mistake. Remember that budget, its gone.
With a complete motor sitting there and a car to go into for some reason the project just stopped. It stayed that way for a few months until we realized powercruise was only a few months away. In a day we got the motor sitting in the engine bqy and the box bolted up. It didn't see, right tho the motor was to high and to far forward. The ppl who had done the last conversion had made a mess of everything which only became obvious now. We had to cut and shut all engine mounts and move the move the gearbox back 50mm. Ok motor in and sitting right, new problem. Cheap ebay manifold was sitting way to high to close the bonnet. Enter 6boost manifold.
Working in wa made life difficult web the car was I. Queensland. Enter good mate and mechanic matt to finish off wat I had started. First things first he cleaned up any un-nessacary lines from the engine bay then called me and cursed me. Once the yelling was done he started wiring up the haltech and brand new loom. Fully heat shrinking every wire and fitting. Wiring complete it was time to sort out oil coolers and lines and intercooler piping. Brand new 2000cc injectors replaced the old 1000cc hks items and 2 brand new in tank walbros were installed in the boot.
Car has made it first run on the dyno now and achieved a impressive 648@whp on 22psi but started pushing oil cos for some reason the baffles had been removed from the tapper covers. We have installed new baffles and now just waiting on new valve springs and retainers to arrive before putting it back on the dyno. Was on full boost by4900rpm and from wat I have been told very nice torque.
Im sure I have missed details out if there is anything u would like to know more about let me know. I'll upload some pics I hope they come out in order.
Thanks guys and thanks to everyone else who has helped along the way
Pic 1 is how I got the car
Pic 2 first mod, new wheels
Pic 3 replacing broken turbo at powercruise
pic 4 new motor ready to go, prior to having 6boost manifold
Pic 5 car ready for transplant
pic 6 hks t51r sitting on 6boost manifold
Pic 7 almost complete
https://www.sau.com.au/forums/topic/405520-project-ooy34/
New valve springs and retainers have been installed, new heavy duty valve proved to be a bit more painful than first thought but all good now. Tuner is predicti g a power increase on less boost just by the upgraded springs. Hopefully Tuesday I will be able to let u know
https://www.sau.com.au/forums/topic/405520-project-ooy34/#findComment-6463749
  • 4 weeks later...
Update. As predicted on the same boost the car went 684 and held power all the way through to 8700 with only very minor drop off. Seen a maximum figure around 730bhp but the car was just turning the tyres at 200km/h.
Can't wait to finally drive this thing at powercruise.
https://www.sau.com.au/forums/topic/405520-project-ooy34/#findComment-6494542
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
