Just had my r34 gtt turbo hi-flowed. It's the op6 rear type witch is a ball bearing turbo. When i got it back it's now a journal type bearing.
Witch type is better Journal or Ball bearing.
The company who did the work are telling me the ball bearing hi-flow turbo will fail, but the journal one will not fail.
Also am i being taken for a ride by the company who did the hi-flow by changeing it to journal type bearing????
Cost was just under $1000 to do the work.
https://www.sau.com.au/forums/topic/405668-just-had-my-r34-turbo-hi-flow/
You will hardly notice the difference between them, stick with the journal, it's easier to rebuild.
What happened to your previous turbo? If the bearings failed and smashed the rear wheel it could be a good idea to make sure the oil feed line isn't blocked.
If the company is one of the reputable turbo reconditioners then you have nothing to worry about. Ball bearing turbos don't seem to be able to handle everything we throw at them but the bush bearing turbos pretty much never fail. Not saying this will be the case for everyone but that is what we have noticed.
There is nothing wrong with journal bearing turbos. Ball bearing is slightly more responsive though.
How does it feel to drive?
Also, under $1000 is cheap
Journal are cheaper to rebuild, but I don't think the stock r34 turbo is a bb though?
Um....that was one of the two main selling points of the turbos used in Skylines (ie things that could be written down the side of the car). Ball bearing and ceramic turbine.
The GTR T28s are plain bearing.
Well there you go, I stand corrected. Either way, nothing wrong with plain bearing hi flows
what about ceramic coating it?? mine runs alot cooler , do you not let the car cool down after a flogging?
i thought that journal bearings were old technology and dont spool up as early so were not the prefered choice.. if your manifold and housing get that hot then could that be also due to the housing being too small and the exhaust too restrictive causing a build up of backpressure...
Edited by SliverS2
What i was saying was not to shut the engine down straightaway and let it cool down for 1min. insted of 30sec. just had the car out for a drive and it used to come onto boost at 2400rpm now it comes on at 3000+ and hits like a freight train and lights it up in second at only 12psi of boost never did this before so will be very interesting when i get it dyno tuned at EFI Profamance in a week or 2.
Going to run 14psi on street and 18-20 at drags.
Shpuld run an easy 11 second pass now.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
