AIR Street drags today, took my R35 out for its first Drag meeting.
I never got a chance to take out my old 2009 R35 & it has been years since
running nines in the R33 so was great to get out there again & do some runs.
First run was a 10.7 @ 128, followed by a 10.9 @ 133, and 10.7 @ 134.
Next run was a shocker, it went into limp mode & ran a 19!
Then finished off with another 10.7 @ 130. Was great fun & now I need to put
a cage in it if I want to come back.
Might have to consider a comeback with the R33. Be interesting to see how it would
go with the Michelin slicks compared to the drag radials I used to run back in the day.
Nice one John, very consistent (except the last one :))
What happened to Kier Wilson half way through his run?
Let me know if you want some video, I think I got your last 3 runs.
Dang that's fast. You'd run neck and neck with me....on my bike! In fact you'd probably beat me more often that I'd beat you. Ultimately my R1 is faster but it takes a far more precise run to go that quick.
And ANDRA are homos.
Seriously, they need to revisit their cage rules for street cars.
Yes I would like to see some video of it.
I think 9.99 sec would be a more realistic cut off for roll cage, chutes, etc.
These days there are plenty of genuine street cars that can run into the tens.
It would be tempting to push down to the 10 flat for lots of quick car owners but
the 10.99 cut off seems to discourage that.
As far as chutes go, I was keeping it flat WAY past the traps - up to 235kmhr on one
run! Still had plenty of time to slow down & could have easily taken the corner without
washing off all the speed. I know it has to be one rule for all but old rules are starting
to get a bit conservative.
I had a great time anyway. Might just get a current ANDRA inspection done on my R33
as that has all the gear.
Nice work mate, could you elaborate on the following things for my own personal knowledge.
1. What year model is your GT-R and what modifications
2. What tyres where you running and tyre pressures
3. Did you use launch control and at what rpm was launch
4. Was it on R R off or R R R
This would help me heaps, I have an 09 with full Exhaust and cobb and would like to get in the 10s this will help me work out if its possible.
Cheers,
2011 with Willall mods - WR600 spec I believe.
New Micheins at 39psi - just drove it in there & went for it.
Yes launch in auto, RRR.
Full weight car, full weight driver! Full tank of juice.
1-2/10s better on 60' would give a 10.3 to 10.5 without too much trouble.
This is my daily so probably wont worry about doing it again - they probably stop me anyway.
Pretty happy with that, was fun to blow past the straight out exhaust V8s that were trailered there!
was good to see the runs munro. be interesting to see with lower PSI.
10.99 is a bit of a joke, plenty of cars there seemed to be running faster with no cage etc (they did seem to be v8's though) and with drum bakes on the rear. think ANDRA do need to re visit and make it 9.99 or something like that
good job
anyway
Hey mate nice run. You say willall wr600 spec for your mods. But on his site wr600 package suggests 600kw... Man if your producing over 800 hp shouldnt you should be cracking the 9's with those numbers? Are you running stock turbos?
No, its not as simple as that.
Go back a few years (ok 10 or so) & there were only a few of us that were pushing up over
450awkw with our GTRs. With 600hp at the wheels (getting up towards 800hp at the crank)
you needed to strip out your car & drive it like you stole it to push into the high nines.
After you spend tens of thousands of dollars breaking driveshafts, gearboxs, engines etc
you go crazy with more power & get into the mid nines, then in Keir's case even crazier &
into the 8s. Back then we were talking 1/4 million plus cars. 1000hp - 1300kg.
Now zoom forward to today. An R35 GTR weighs in around 1800kg with some fuel in it.
Even with 800hp, the launch control system will only give as much torque as it thinks the
treads can take - it might halve the power for that precious 1.5 seconds or so that you are
trying to move 1800kg (plus driver) over that first 60 foot.
Elapsed time on the 1/4 is ALL about the 60' time. GTRs are not designed for this.
Engine tuners just look at the mph to see what a car COULD do if it got the perfect world hookup.
My best mph on the day was 134mph. Good for a flat 10.
Back in the 90's I used to run a small block HJ ute in Super Sedan.
It ran 10.1 all day at 133mph.
With 600hp!
But it couldnt stop. Or corner.
GTRs are amazing street & circuit cars that just happen to be a bit handy down the 1/4.
With 600hp!
well said:) and their is an extra 40KG ballast in the driver seat now J/K
my 32 with 400 managed mid 10's and to get any better would cost an absolute fortune.
your 33 was a weapon to get in to the 9's and look at all the comfort and style of your 'daily 35' to be just that 1sec slower:) i know which id rather.
now run the ML:)
haha. ML. now that would be funny. They are supposed to run 12.9 sec!
Martin reckons he got another 100hp out of Keir's CLS with the twin turbo 5.5L
so maybe I should let him hook up the cables to the ML & see what the fourby can do!
I think the XR6 should be next in line for a day at the drags - has been a LONG time between drinks..............
Maybe next time I take the R33 out I should ask them if I can take the tow car for 1 run - just for fun!
With 600hp!
Was that ute yellow?
It's funny the difference between the Na v8s and the turbo cars
A good mate of mine runs mid-high 10s in a full weight xa Tudor with 425rwhp but given a manual box it would have a whole heap more, so don't discount the r35 off the line as pound for pound your car sounds like it gets off the line well
What I do love seeing is that xa on 15x9s and drag radials beating the guys with 15x14s tubs and huge slicks, ladder bar rear ends etc but they are a second slower then an angry streeter
ill run the ute for you:)
someone said you maybe willing to sell the ute? i sent you a PM too:)
Ps you should run the 33 more, I saw it ah heathcote (or was it spring nats?) years and years ago
Edit - would've had to be heathcote, because from memory you broke a front shaft or something and I was pissed because I was stuck with shit tyres and running low 14s at 105 in my blue r33
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
