Ok, so, jumped on the Wii scales last night and came back at a whopping 118.5kg!
apparently, I should be around 75kg?
I don't have the smallest frame, but Fark me!
I am one fat Kent.
so, going to start a log in here of daily or more probably, weekly progress to try and keep me motivated.
the 2 biggest hurdles I face are:
laziness....
I like to sit on my ass and watch tv.
food.....
I generally don't like the taste of most healthy things.
any tips and suggestions will be considered and taken on board.
so, here we go.
https://www.sau.com.au/forums/topic/405864-lukes-fatness-diary/
Ha! Nice thread Luke... Might motivate me not to be a fat Kent! Although i am still 8kg or something up on ya :/ Farrrrrrk!
My poor excuse is leg injury which severly limits ability to exercise, but its a bullsh*t excuse as there are plenty of ways to do it :P
Team Fat Kunce :yes:
Motivation:
Last night dinner consisted of a massive pizza and a box of pringles.
Today, pre-dinner was maccas meal followed by dinner, lol.
Seriously though, keen to see progress :thumbsup:
I think I'm broken....this made me feel sick and I know it shouldn't :P
I'm in a similar situation.
I was 117kg
I am now 104kg I did go up and down from 105-110 allot.
Now I'm keen to keep up motivation and get down under the 100 mark, that's my first goal.
This is what I'm doing
Diet:
7am good cerial and banana
10am 2 boiled eggs
12pm 200g salad with 200g chicken (chillie adds weight loss)
3pm small tub of no fat yoghurt and piece of fruit
Dinner, something good.
Gym: (join a gym spend the money and you will go)
I will get my workout schedule for you but I go 4 days a week rotating upper body day, core day, legs day, and cardio day
Been going for 2 weeks, lost 4kg and I'm starting to put on muscle aswell.
Very happy with results.
I also have a bad day with Mates with pub meal drinks which you can do.
Edited by GH05T
Don't know about the gym.
I used to be a member, and stopped going.
cost me a small fortune in not going.
at the moment, looking to buy a mountain bike and start riding of a night.
ok, lunch was a chicken and gravy roll, with a side if ceaser salad.
will be doing another walk tonight.
eventually, would like to be down into double digits.
thanks for the support.
ps, box, cylinder, canister or jar, they're still Pringles.
and I ate around a third for breakfast/morning tea.
Hey mate, personally for me paying for a gym membership is my ONLY motivation to excercise (I'm stingy like that hehe can't stand to see money down the drain). Try to find your motivator as it will definitely help you persevere when you have times when you just want to say f**k it all.
I had to take a long hard look at myself to realise that the pain in the arse of eating healthier & excercising outweighs feeling shit about myself.
I'm at a point now where I'm enjoying my workouts, (the perve when I'm on the treadmill/eliptical is a good motivation to go too :woot: ) still trying to get the eating side under control.
Good luck, hope things stay on track for you :thumbsup:
Thanks yo-yo.
had a bad day yesterday, so was shit all round.
buying mountain bike tonight to try and get me moving.
gyms don't work for me, as I hate running or riding on one spot.
prefer to be outdoors.
I've already gone waaaay off track.
so, hope to get back on it.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
