Same as Sean, sometimes peaks at over 2000rpm on cold mornings, but only for a second, then quickly drops back to about 1500rpm, then drops slowly until the engine is warm, then sits on 600.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6467569
One thing i have noticed though when i park my car over night outside and i drive in the morning, the engine sounds a lot better cold than warm (normal) but it feels a little bit gutless until it's warm but that just may be because i have it overnight 12 hours or so in 10ish degree cold.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6467632
you might need an oil change? how long until your next?
or one of your O2 sensors might be faulty/dirty.
or it's really cold
Flushed and changed my oil last weekend, o2 sensors are fine checked those a few weeks ago too.
He's in Mackay... It doesn't get cold.
Not true man! 2 weeks ago it hit 4 degrees here at night/morning
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6467930
not sure why it does it.. the VQ35 in other cars doesn't rev that high.. but it does seem normal for the V35.
My Stagea revs to about 2400 for a second from first start in the morning and then drops as it warms up. Always has.
Damn thing won't drop below 750 when warm...
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468121
have you done the idle air volume learn procedure?
After cleaning my throttle body, it wouldn't idle much below 900 until I ran this process.
I guess the VQ35 in the Stagea is probably setup the same. The VQ35 in the Murano and Maxima don't rev anywhere near as high at cold startup.. not sure why our cars need to?? I know they are tuned differently, but I am not sure why that would make a difference.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468173
i remember my startup revs situation started happening after installing the 350z intake tube. did both the throttle learn and idle air volume procedures multiple times with no improvement. there are absolutely no leaks anywhere.
its something i want to fix before installing the plenum spacer.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468331
I did indeed. Prior to the relearn, it liked idling at 950rpm when warm.
Far cry from my old VQ25det Stagea that idled at 550 when warm.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468430
I have a cable (+ laptop) & can set the idle to whatever I like (within reason). I should send it down to you one day; if no one in Melbourne has one you can borrow.
Edited by Commsman
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468491
I'm far from an expert on any of this but is it possible that the vq35 in our cars reacts differently than other models due to being released for the Japanese market? It gets extremely cold there so maybe it is required for that climate??
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468540
Usually, and don't quote me on this :D they will rev higher on startup to heat up cat coverters quicker for emissions reasons.
A mate's 350ZHR did the same thing.
I would say this probably isn't the reason, the revs only peak to 2000rpm for a second then drop back to about 1500rpm, which is where most cars idle when cold. If the intention was to heat the cats and O2 sensors, it would need to stay at high rpm for much longer.
https://www.sau.com.au/forums/topic/405987-revs-at-startup/#findComment-6468684
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
